jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I'm in the process of putting 911 brakes up front.
I have 2 sets of calipers and noticed one at has a wider space between the 2 caliper halves than the other set. Are there different thicknesses of rotors or what is the purpose and how do I know which one to use? Just test fit and use prices of elimination I suppose? Attached thumbnail(s) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Early is 20mm, Carrera is 24mm
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 882 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) Do those calipers have the same spacing - 3” or 3.5” What front hubs are you using? Eric is the one to ask regarding all the compatibility. |
Freezin 914 |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) Do those calipers have the same spacing - 3” or 3.5” What front hubs are you using? Eric is the one to ask regarding all the compatibility. All 3.5” Maybe Jeff will chime in…..not sure if he has different parts from what I had sold him. |
Lo-Fi Version | Time is now: 27th June 2024 - 05:50 PM |
