> Model Specific Information
> VIN Page
robkammer
post Jan 8 2021, 05:28 AM
Hello all: I'm new to the 914 world and am hoping to add a 2.0 to our garage soon. I have seen references to a VIN page in the forums but can't find it on the site.
Can someone point me in the right direction?
Thanks
wonkipop
post Apr 5 2024, 01:46 AM
here is a mission for you @JeffBowlsby .
its to do with LEs.
it might get one more engine stamp number.
for 1974
all USA 2.0s were GA engines with 621 stamp.
(low comression 7.6 : 1, 95 hp.)
European 2.0s were GB engines with 620 stamp.
(high comression 8.0:1, 100 hp).
but japan
definitely the high compression engine.
8.0:1.
and japan had introduced the vapor emission system.
(along with australia).
europe did not have vapor emission system.
so its a unique engine. euro compression internals and vapor emission system.
see images below. matsuda 914 engine bay has the can in it like all usa 74s.
which meant it had to have a drilled out fan casting with the inset sleeved tube to take the blower bleed hose to the charcoal cannister. euro cars did not have that.
and given the engines were built in hanover that meant it had to be built that particular way and identified so the correct engine was delivered at osnabruk and put in the right car on the assembly line.
i'm betting that matsude 914 that @dr914 has in his collection has neither 620 or 621 stamped on it. ie it won't have a ROW number on it just because its not a USA engine. but it will be likely in the 62....X range. maybe 622?
maybe you can find out?
its interesting in terms of LE information and more broadly.
(it means there would have been a range of J spec engine stamp code numbers because they are all euro spec internals with USA vapor emission provision on the blower casting).
it will be further evidence for my theory on engine stamp numbers.
remembering its only a theory. (IMG:style_emoticons/default/biggrin.gif)
robkammer   VIN Page   Jan 8 2021, 05:28 AM
bretth   Hello. Click the 914 info link up top. :wttc:   Jan 8 2021, 07:29 AM
robkammer   Thanks, found it! Where can I use the VIN to f...   Jan 9 2021, 09:26 AM
914werke   quick answer: you cant. The vin wont provide any o...   Jan 9 2021, 10:03 AM
davep   Well, in actual fact you could use the VIN to acqu...   Jan 13 2021, 11:55 AM
914werke   Well, in actual fact you could use the VIN to acq...   Jan 13 2021, 12:24 PM
davep   To clarify, in the U.S. without taking your car t...   Jan 15 2021, 11:30 AM
rhodyguy   :toke:   Jan 13 2021, 12:33 PM
914werke   :D Dave I suggest you cut down on the coffee. I m...   Jan 15 2021, 12:19 PM
Pat Garvey   chill   Jan 16 2021, 06:02 PM
robkammer   Hey all! The Bumblebee that I was courting was...   Feb 12 2021, 07:10 AM
davep   That is excellent Rob. I am gathering the last bit...   Feb 12 2021, 10:29 AM
robkammer   That is excellent Rob. I am gathering the last bi...   Apr 2 2022, 09:36 AM
RMF6   Hi Folks. I'm new to this forum and don't...   Apr 6 2022, 09:54 AM
FlacaProductions   David can give you initial/as-delivered info off t...   Apr 6 2022, 12:04 PM
914werke   Do you have an ad here in the members section? Ot...   Mar 4 2024, 12:51 PM
914werke   So after a couple of cocktails one eve I send off ...   Mar 28 2024, 12:05 PM
914werke   The seat cushion thing was odd. The PPS I received...   Mar 28 2024, 12:10 PM
JeffBowlsby   Rich, Option M570 was a center seat cushion as in...   Mar 28 2024, 06:54 PM
914werke   Rich, Option M570 was a center seat cushion as i...   Mar 29 2024, 01:17 PM
JeffBowlsby   [quote name='JeffBowlsby' post='3136491' date='Ma...   Mar 29 2024, 01:23 PM
davep   All 914 (4&6) would have as standard equipment...   Mar 29 2024, 08:07 PM
914werke   Thanks for the confirmation, I learn something abo...   Mar 31 2024, 05:12 PM
wonkipop   Thanks for the confirmation, I learn something ab...   Apr 1 2024, 06:03 PM
wonkipop   as an aside. i have often looked at the parcel bi...   Apr 1 2024, 06:17 PM
wonkipop   snooped around in my files which are mostly re 74 ...   Apr 1 2024, 10:15 PM
wonkipop   i would speculate the following (with reasonable b...   Apr 1 2024, 10:40 PM
JeffBowlsby   I'm still processing the above, but here are a...   Apr 2 2024, 07:42 AM
wonkipop   I'm still processing the above, but here are ...   Apr 2 2024, 02:50 PM
wonkipop   I'm still processing the above, but here are ...   Apr 2 2024, 03:48 PM
wonkipop   I'm still processing the above, but here are ...   Apr 4 2024, 03:47 PM
wonkipop   As another little bit of info. we did find one 74 ...   Apr 2 2024, 03:16 PM
wonkipop   @JeffBowlsby this was the one and only 74 1.8 th...   Apr 2 2024, 06:37 PM
wonkipop   and i trawled the files on the 74 1.8 s. 79 exampl...   Apr 2 2024, 06:44 PM
wonkipop   @JeffBowlsby . here is some stuff i isolated out a...   Apr 2 2024, 09:59 PM
wonkipop   and here is the other one from the 75 brochure. U...   Apr 2 2024, 10:31 PM
JeffBowlsby   Checking a few archives: The center gauge console...   Apr 3 2024, 10:48 AM
wonkipop   Checking a few archives: The center gauge consol...   Apr 3 2024, 03:06 PM
gandalf_025   Going back to the center cushion questions.. Does...   Apr 3 2024, 10:57 AM
914werke   Per my OG post my PPS just showed "Seat cushi...   Apr 3 2024, 12:32 PM
JeffBowlsby   Center seatbelts were optional equipment M166 (US ...   Apr 3 2024, 02:23 PM
JeffBowlsby   Center seatbelts were optional equipment M166 (US...   Apr 3 2024, 08:26 PM
gandalf_025   Does anyone have an idea of how many cars were opt...   Apr 3 2024, 02:39 PM
wonkipop   Does anyone have an idea of how many cars were op...   Apr 3 2024, 03:25 PM
gandalf_025   From what I understand the center belt was only of...   Apr 3 2024, 05:06 PM
mepstein   I’ve only seen center belts in early cars and my...   Apr 3 2024, 08:43 PM
wonkipop   I’ve only seen center belts in early cars and m...   Apr 3 2024, 09:42 PM
JeffBowlsby   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 3 2024, 10:16 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?show...   Apr 4 2024, 01:16 AM
wonkipop   i've also worked out some details of my car an...   Apr 4 2024, 04:13 PM
wonkipop   here is a mission for you @JeffBowlsby . its to ...   Apr 5 2024, 01:46 AM
JeffBowlsby   NICE. Verifying the engine tin number on the Mats...   Apr 6 2024, 09:26 PM
wonkipop   NICE. Verifying the engine tin number on the Mat...   Apr 7 2024, 04:20 PM
wonkipop   i'm pretty sure its 74 that australia introduc...   Apr 7 2024, 04:33 PM
wonkipop   found out a little bit more on japanese and austra...   Apr 9 2024, 03:29 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:26 AM
