Flappy, Bouncy, Wacky Tachometer?!, Tachometer bounces back and forth while driving at constant speed |
vjb206 |
Feb 25 2023, 08:59 AM
Newbie Group: Members Posts: 30 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States |
Hi folks! First time/long time for me here in the Garage. I just purchased a '74 1.8 in Ohio and it died on me in PA on the way home to NJ. Right before it died I noticed this bouncy/flappy tach thing happening.
(IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1677337178.1.gif) As you can see my speed is constant, my throttle inputs steady – just cruising. However the tach is going nuts. When the car died (in a rest area off I-80 in PA) it would turn over but not start. We ran some rudimentary diagnostics and remediation measures: - Heard clicking/popping noise coming from driver's side of engine bay at speed, this was accompanied by the flappy tach phenomenon - Generator light came on at some point while driving - When flappy tach/popping noises would happen, I'd notice the car losing power for a split second - Electrical systems stopped working during my drive (door open buzzer stopped working mid-way through the trip) - Replaced the battery with a brand new one, no dice - Power at the coil - No spark at the plugs Car is at a shop in PA - they will get to diagnosing it over the next few days. I'd prefer to fix myself, but I can't get it home from where it is without basic drivability. Has anyone ever had this happen? Is the flappy tach a symptom of a larger electrical issue? I found the post on adding the 2200uf capacitor to stop bouncing when changing RPMs rapidly, but I don't think this is that issue. Especially since the bouncy tach and the car dying are correlated (I think). Would love to tap into the collective wisdom of the platform to help point me in the right direction. |
brant |
Apr 9 2024, 12:30 PM
914 Wizard Group: Members Posts: 11,831 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
did you use a dwell meter when replacing the points?
they can wear in a lot when they are new. if it has a few hundred miles on it since they were replaced.. it might be worth rechecking the dwell and resetting the gaps no guarantee but they might clean up the signal and help some more after the wear in. I think the signal will be better after the 123 install might be worth buying that early in the new project and getting the benefit of having it on the old motor before the new motor. |
Lo-Fi Version | Time is now: 15th January 2025 - 09:35 AM |
