Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,494 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Trying to wrap my head around the PET illustrations for the windshield washer pump.. There is an illustration for an electric pump which is what I'll be using, however it seems to only call for "T" pieces - but I believe that's being shown with the early chrome nozzles.
Did maybe early nozzles incorporate a check valve, but the later black one didn't? The illustration for the later black nozzles lists a "T" shaped "valve with valve" (probably a separate check valve, no?). Anyone know what's what here? . |
East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,699 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
Check valves are one-way valves. Are these really pop-off valves instead? Pop-off would allow spray but not weeping/leaking. I just did my electric pump install but did not include any valves, maybe I need to reconsider. I’m curious why 2 valves instead of 1 valve before they branch to the 2 nozzles.
Nate W |
Member ![]() ![]() Group: Members Posts: 77 Joined: 23-February 21 From: Oceanside, Ca Member No.: 25,250 Region Association: Southern California ![]() ![]() |
Check valves are one-way valves. Are these really pop-off valves instead? Pop-off would allow spray but not weeping/leaking. I just did my electric pump install but did not include any valves, maybe I need to reconsider. I’m curious why 2 valves instead of 1 valve before they branch to the 2 nozzles. The early nozzles have 1 check valve each, but the later models (black nozzles) use a “T” fitting that has a single check valve |
Lo-Fi Version | Time is now: 26th June 2024 - 01:28 AM |
