> Anyone tried an aircooled Flat 8, With two fours?
r_towle
post Jan 28 2005, 12:49 PM
Custom Member
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions.
Assumptions
2 motors each producing 100 HP and 100 Lb/ft of Torque
The motors are end to end, front to rear.
The cranks are fastened together either bolted or welded.
1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque..
2) could it be done with a single ignition system available for sale off the shelf.
3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from.
4) I am assuming either a nice FI system, or four carbs.
Has anyone done this?
I would like to see some articles or web pages if this has been done in the aircooled world...
Thanx in advance
Rich
Brando
post Jan 29 2005, 05:12 AM
BUY MY SPARE KIDNEY!!!
or connect them at the cranks...
if you're going that far, might as well go the route of merging two 911 cases...
r_towle   Anyone tried an aircooled Flat 8   Jan 28 2005, 12:49 PM
Mueller   yep, a few have been done........I know I've p...   Jan 28 2005, 01:03 PM
sanman   I thought of it but I think it would be too lo...   Jan 28 2005, 01:05 PM
r_towle   i was hoping you would answer...you always think o...   Jan 28 2005, 01:05 PM
andys   It's been done both ways. I saw a pic years ag...   Jan 28 2005, 01:08 PM
r_towle   honestly cooling seems like a simple part of it .....   Jan 28 2005, 01:14 PM
Cloudbuster   Double displacement does not usually equal double ...   Jan 28 2005, 01:22 PM
nebreitling   i would think that you could never get double the ...   Jan 28 2005, 01:36 PM
Jake Raby   Already have a print in with moldex on the crank. ...   Jan 28 2005, 01:59 PM
synthesisdv   asked the same question a while back.... here...   Jan 28 2005, 02:19 PM
Cloudbuster   Hans Dahlbeck? Isn't he the brain donor in ...   Jan 28 2005, 02:23 PM
synthesisdv     Jan 28 2005, 05:29 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 28 2005, 06:06 PM
Jake Raby   It won't cost a whole lot for me to do it, oth...   Jan 28 2005, 06:10 PM
Mueller   ...   Jan 28 2005, 06:13 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 28 2005, 06:28 PM
Bleyseng   screw two motors! put four of them together...   Jan 28 2005, 06:48 PM
redshift   <...   Jan 28 2005, 06:59 PM
Bleyseng   I am hoping to squeeze by with $5000, buying ...   Jan 28 2005, 07:01 PM
Jake Raby   Here it cost 6K for a stock rebuild, but you can a...   Jan 28 2005, 08:16 PM
r_towle   how would you do oiling on the rear engine??? See...   Jan 28 2005, 11:23 PM
SpecialK   Screw pistons...........someone stick a Huey Turbi...   Jan 29 2005, 05:18 AM
BigD9146gt   http://www.914world.com/bbs2/html/e...   Jan 30 2005, 05:19 PM
r_towle   ok, When if any was the earliest time that an ove...   Jan 30 2005, 06:09 PM
DuckRyder   Thinking out loud: Couldn't you slice one cas...   Jan 30 2005, 06:18 PM
r_towle   <...   Jan 30 2005, 07:21 PM
URY914   Here's what you need...   Jan 30 2005, 08:09 PM
redshift     Jan 30 2005, 08:14 PM
URY914   <...   Jan 30 2005, 08:18 PM
Air_Cooled_Nut
  Jan 31 2005, 11:23 AM
jwalters   Wonder how the T4 would respond with a crank that...   Jan 31 2005, 02:47 PM
bondo   ...   Jan 31 2005, 02:50 PM
r_towle   yes, but what if you welded up the two motors to b...   Jan 31 2005, 05:28 PM
DuckRyder   ...   Jan 31 2005, 05:45 PM
jwalters   Very nice pic of a Duc!!! I am spankin...   Jan 31 2005, 05:52 PM
DuckRyder   ...   Jan 31 2005, 05:56 PM
JmuRiz   I know were're getting off topic here, but mmm...   Jan 31 2005, 11:06 PM
BigD9146gt   Nathan, I second that! MotoGP sould be great t...   Feb 1 2005, 12:34 PM
Al Meredith   I was out at Chuck Beck house (he lives outside At...   Feb 27 2006, 06:34 PM
Mueller   ...   Feb 27 2006, 07:15 PM
ClayPerrine   How about something like this??? http://www.perr...   Feb 27 2006, 07:51 PM
Mueller   ht...   Feb 27 2006, 08:01 PM
bd1308   i'll see if i can dig up two bus motors.... T...   Feb 27 2006, 08:02 PM
Brian Mifsud   Mike...while your in there pouring aluminum, how a...   Feb 27 2006, 08:22 PM
Brando   ...   Feb 27 2006, 08:54 PM
Brett W   The 180 degree 8 has a problem with second order i...   Feb 27 2006, 08:56 PM
Thorshammer   One of the problems must be the design of a crank ...   Feb 27 2006, 08:58 PM
alpha434   Why we couldn't use a Chevy crank: Counter ba...   Feb 27 2006, 09:03 PM
ClayPerrine   <...   Feb 27 2006, 09:06 PM
alpha434   ...   Feb 27 2006, 09:07 PM
lapuwali   ...   Feb 27 2006, 09:22 PM
Brett W   Sorry I was referring to a 180 degree V8. Don...   Feb 27 2006, 09:23 PM
JmuRiz
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 05:52 AM
