> SCCA catagory for my 914-4, racing catagory 914
FastFroggy
post Apr 29 2024, 12:40 PM
Hello all,
I previously ran HPDE events and autocrosses prior to my engine issue. I am now wrapping up my 914-4 rebuild and just passed my SCCA Licensing Class. Really enjoy running the car. Would like to see if there is an SCCA class I can fit it, but looks tough. Looking for guidance on the best path forward given my stated priorities:
1. SCCA regional level minimum
2. Extent of further modification needed
3. Relative competitiveness in class
My car:
a. 1973 914-4 with up to date safety items(Cage, extinguisher, seats, harness, etc)
b. 2.0l stock internals
c. race headers
d. large bore twin carbs
e. 5 lug conversion
f. 911 1973 rotors
g. 911s calipers front
h. fiberglass fender flares
Please PM me with feedback. Thanks, GregM
GregAmy
post Apr 30 2024, 08:14 AM
Some updates.
I'm reviewing the regs, and the following is the fuel cell requirement (GCR 9.3.26):
"All cars must be equipped with a safety fuel cell complying with these specifications, except for Touring, B-Spec, C-Spec, Spec Miata, Improved Touring, American Sedan restricted prep, production-based Vintage cars, and cars where the stock fuel tank is located between the axle center lines and within the main chassis structure (i.e., frame rails, etc.)."
I believe the stock fuel tank meets the highlighted allowance and thus should not re required.
If you choose to go with a cell, it's generally installed in the front trunk (that's where it is on my historics racer). But if I were feeling really flush...I do like this setup:
https://patrickmotorsports.com/products/fuesa914pms
As for other "safety" mods...
Roll cage: you'll need two tubes going forward to the firewall, and a lateral brace between the front legs "at the approximate level of the dashboard."
And what tires are you going to run? My car has a long history of oil starvation when we started to go to Hoosier tires in the early-00s, tossed a couple engines in the process. The resolution was dry sump. If you're going to run anything stickier than 200TW tires you might give that some thought (and I personally do not perceive an Accusump as an acceptable long-term solution to address that design shortcoming).
FastFroggy   SCCA catagory for my 914-4   Apr 29 2024, 12:40 PM
GregAmy   Oh boy, big long discussion...but let's start ...   Apr 30 2024, 07:16 AM
GregAmy   Some updates. I'm reviewing the regs, and the...   Apr 30 2024, 08:14 AM
FastFroggy   Thank you GregA, Lots of good info. I have been ...   Apr 30 2024, 11:03 AM
GregAmy   I'll PM you to continue the discussion if that...   Apr 30 2024, 02:31 PM
ChrisFoley   Regarding fuel cells, my Production car custom fue...   Apr 30 2024, 12:32 PM
BillJ   If going racing (circuit course not autox) then ge...   Apr 30 2024, 12:39 PM
FastFroggy   BillJ, you bring up a very good point. The 914 is ...   Apr 30 2024, 04:19 PM
GregAmy   Previously ITA logbook(lost to time) out in Colora...   Apr 30 2024, 08:11 PM
brant   You should probably show us a picture I might ev...   Apr 30 2024, 07:01 PM
ChrisFoley   EP will restrict you to 7x15 wheels, 40mm carbs, a...   May 1 2024, 04:48 AM
GregAmy   Chris, we have a new brake rule in Prod, think it ...   May 1 2024, 06:50 AM
FastFroggy   Thanks for all the insight. Really appreciate it. ...   May 1 2024, 06:54 AM
GregAmy   Do you have your schools signed off yet? What...   May 1 2024, 07:49 AM
FastFroggy   Yes, I have my school signed off. Plan is to hav...   May 1 2024, 08:40 AM
ChrisFoley   914-6 has vented front and solid rear rotors. Usin...   May 1 2024, 10:59 AM
FastFroggy   batter batter swing..... on photos. Will take a da...   May 1 2024, 02:51 PM
Charles Freeborn   ... then there's vintage. You'd be in VP2 ...   May 3 2024, 08:21 PM
brant   ... then there's vintage. You'd be in VP2...   May 4 2024, 07:32 AM
GregAmy   what is the displacement again? For historics raci...   May 5 2024, 07:04 AM
Charles Freeborn   [quote name='Charles Freeborn' post='3143151' dat...   May 5 2024, 09:03 PM
brant   No matter what sanctioning body Classes often incl...   May 5 2024, 09:24 AM
FastFroggy   Just noticed that I missed a few questions. a. y...   May 6 2024, 05:38 AM
FastFroggy   Thanks again for all who are contributing. Been ...   May 6 2024, 03:24 PM
GregAmy   ...I am considering to class the car in GT3. I wou...   May 7 2024, 07:09 AM
Charles Freeborn   Your SCCA license will work for pretty much any am...   May 6 2024, 09:06 PM
FastFroggy   Hope this finally works, will get photos of the fr...   May 7 2024, 07:24 AM
GregAmy   >>> I'd need to see your cage... Loo...   May 7 2024, 08:33 AM
moto914   Great thread.   May 7 2024, 10:20 AM
FastFroggy   Thanks for the clarity of feedback. I have a follo...   May 7 2024, 12:47 PM
GregAmy   Arm Restraints are required for the Targa, but it ...   May 7 2024, 01:27 PM
ChrisFoley   IIRC, in the production classes, if you remove the...   May 7 2024, 02:41 PM
groot   You're local to me... and if I recall, you may...   May 7 2024, 05:38 PM
brant   Nice to see you here kevin   May 7 2024, 05:46 PM
groot   Thanks, Brant... I stalk every once in a while... ...   May 7 2024, 05:54 PM
GregAmy   The whole open-top/closed-top thing is a PITA and ...   May 8 2024, 06:53 AM
gms   you might want to check out VSCDA and Midwestern ...   May 8 2024, 09:36 AM
FastFroggy   GregAmy, Somewhat glad to hear I was the only one ...   May 8 2024, 11:57 AM
Charles Freeborn   Fun looking car. Similar to my last one built by A...   May 9 2024, 10:43 AM
infraredcalvin   Raising Arizona :lol4: @GregAmy   May 10 2024, 09:18 PM
Charles Freeborn   Raising Arizona :lol4: [b]@[url=http://www.91...   May 11 2024, 10:12 PM
GregAmy   :beer2:   May 11 2024, 05:33 AM
FastFroggy   Progress from Saturday: engine and trans finally b...   May 16 2024, 09:02 AM
FastFroggy   Does anyone know where I can find the missing chok...   May 16 2024, 09:03 AM
ChrisFoley   Does anyone know where I can find the missing cho...   May 18 2024, 12:47 PM
FastFroggy   Does anyone know where I can find the missing ch...   May 20 2024, 06:46 AM
FastFroggy   update from this weekend: Still needs tidying up...   May 16 2024, 09:03 AM
FastFroggy   oops..   May 16 2024, 09:03 AM
Charles Freeborn   https://www.carburetion.com/   May 18 2024, 08:53 AM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:55 AM
