> Factory 911 air cleaners, What fits what?
mate914
post May 6 2024, 04:29 PM
Matt
I recently picked up a 911 mechanical fuel injection, air cleaner assembly . I was hoping I could use this with the carburetor Air cleaner base unit I already have. I was wrong once again. Can anyone point me in the right direction on how to make this set up work? I have no problem making custom clips to attach to. Has anybody modified a plastic air cleaner to work with Zenith air cleaner base mounts.
MattAttached Image Attached Image
rgalla9146
post May 10 2024, 06:48 AM
Hey Matt
What doesn't fit ?
You have a 6 air filter, Zenith boats (same as Webers) and Weber carbs.
When installing the stock air filter housing in the car it is a bit of a wiggle.
Attaching the drain hose, the big vent hose and flipping a couple of the clips is
annoying.
Doesn't sound like any adaptation is necessary except for correct clips.
mate914   Factory 911 air cleaners   May 6 2024, 04:29 PM
mate914   RE: Factory 911 air cleaners   May 6 2024, 04:31 PM
mb911   So you have an MFI top as you know and carb bases....   May 6 2024, 05:07 PM
rgalla9146   Hey Matt Don't modify anything yet. I...   May 6 2024, 05:12 PM
rgalla9146   Hey Matt Don't modify anything yet. ...   May 6 2024, 06:17 PM
mb911   Hey Matt Don't modify anything yet. ...   May 6 2024, 06:20 PM
rgalla9146   Did MFI air filters have the enrichment spray part...   May 7 2024, 06:17 PM
rgalla9146   And one more. I hope this helps. And congr...   May 7 2024, 06:46 PM
mate914   And one more. I hope this helps. And cong...   May 8 2024, 05:03 AM
Tom1394racing   I would suggest that you get an early steel airbox...   May 8 2024, 07:58 AM
mate914   I would suggest that you get an early steel airbo...   May 8 2024, 02:34 PM
930cabman   I am going through this now with a /6 conversion I...   May 8 2024, 09:01 AM
930cabman   DP   May 8 2024, 09:01 AM
mb911   You can see how I had to modify mine to clear ever...   May 8 2024, 03:51 PM
mb911   RE: Factory 911 air cleaners   May 8 2024, 04:00 PM
nditiz1   Zenith and weber use the same bases   May 8 2024, 04:24 PM
mb911   Zenith and weber use the same bases Correct   May 9 2024, 08:29 AM
zulu33   Hi Matt, it looks good. Maybe it's just put to...   May 9 2024, 11:07 AM
rgalla9146   Hey Matt What doesn't fit ? You ha...   May 10 2024, 06:48 AM
mate914   Hey Matt What doesn't fit ? You h...   May 25 2024, 11:58 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 07:16 PM
