Wiring harness snorkel, 91461201810 |
Van B |
Jun 15 2023, 04:53 PM
Senior Member Group: Members Posts: 1,613 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
https://914rubber.com/wiring-harness-snorkel-tube-1
I know this has been discussed before, but there was no thread specific to the issue and I couldn’t find the discussion. So, I wanted to post one that others can find. Bottom line, I don’t know the scope or differences among years and models, but the wiring harness snorkel sold by 914 rubber, definitely does not fit my 74. @Mikey914 any chance you’d be willing to make one with a proper size top for whatever years have this size? Or, does anyone know a source for one that will fit my 74? |
JeffBowlsby |
May 15 2024, 09:27 PM
914 Wiring Harnesses Group: Members Posts: 8,550 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Not that hard to install. It’s only wiring for the rear trunk lights, the relay board (r/r the plastic 14 pin housing), the battery cables and the fuel pump (r/r the connector housing). Use wire lube to pull the wires through the grommet. Easy enough.
ClayPerrine |
May 17 2024, 10:07 PM
Life's been good to me so far..... Group: Admin Posts: 15,544 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Not that hard to install. It’s only wiring for the rear trunk lights, the relay board (r/r the plastic 14 pin housing), the battery cables and the fuel pump (r/r the connector housing). Use wire lube to pull the wires through the grommet. Easy enough. (IMG:style_emoticons/default/agree.gif) I am rewiring the engine compartment on my six conversion for the MS3Pro. So while I am at it, I installed a new snorkel. Getting it in is not difficult. Just time consuming. (IMG:style_emoticons/default/slap.gif) Don't half ass it. Do it right the first time. |
Lo-Fi Version | Time is now: 18th June 2024 - 07:14 AM |
