CCE |
CCE ![]() ![]() Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille ![]() ![]() |
Just installed a Bluetooth amp to my car, to clean the dashboard with a blank faceplate, I ran a cable direct to my battery but I am getting the amp to shut down protecting maybe because of an overload since it doesn’t get energy from the regulated board I think. Can anyone confirm if my assumption is correct or if my regulator is not regulating correctly.
Thanks. I updated the photo. And my wires ![]() |
technicalninja |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,432 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
What's up with the single ground to chassis only?
At a minimum I want a chassis ground like you have AND an even larger cable direct to engine/transmission, the closer to the starter the better... Optimal is big ground (large battery cable) to starter mount, medium ground (10 gauge or better) to engine close to alternator. Then 2 big (small battery cable) to chassis. One at normal spot and one behind/beneath the dash. For the front one I'd put in a grounding bar similar to what you find in your home electrical panel. That would allow me to add ground circuits at will from the dashboard appliances. I sorry I don't have a direct answer to your question. IMHO you need grounds BAD! |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,016 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
What's up with the single ground to chassis only? Standard automotive practice on both vintage and modern vehicles. Picture below is battery negative cable for BMW E70 X5. Although it has a device incorporated (shunt resistor) to allow all current draw to be measured - all current is still sourced from a single ground connection to chassis and battery negative. Very modern but still a single ground ![]() |
Lo-Fi Version | Time is now: 27th June 2024 - 08:24 PM |
