CCE |
CCE ![]() ![]() Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille ![]() ![]() |
Just installed a Bluetooth amp to my car, to clean the dashboard with a blank faceplate, I ran a cable direct to my battery but I am getting the amp to shut down protecting maybe because of an overload since it doesn’t get energy from the regulated board I think. Can anyone confirm if my assumption is correct or if my regulator is not regulating correctly.
Thanks. I updated the photo. And my wires ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,016 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
@CCE
I’m trying to find Blaupunkt documentation for this amp but looks to be very poorly supported. What are the symptoms with the amp? When you say it’s shutting down from overload what do you mean by that ? The main thing that I can see from back panel online is that the remote (rem) terminal needs to have switched 12v to power the amp on. How do you have the amp and speakers wired? Photos would help. Have you checked your speaker wiring to make sure you don’t have short circuits there? |
CCE |
@CCE I’m trying to find Blaupunkt documentation for this amp but looks to be very poorly supported. What are the symptoms with the amp? The main thing that I can see from back panel online is that the remote (rem) terminal needs to have switched 12v to power the amp on. How do you have the amp and speakers wired? The amp just shuts down as soon as I accelerate the motor under load. 1st gear or second. It blips, and starts again 5 seconds later. Can’t really use it. The amp has a remote on connection, I installed it to the fuse board on a free tab that opens with the ignition on I also installed a switch just to disconnect when not in use to interrupt the remote line in. Speakers run direct to the doors and all connector I installed with ferrings and thermofit. I liked very much my install until it did not work! (IMG:style_emoticons/default/confused24.gif) all is under. The dash and does not show. ![]() |
Superhawk996 |
@CCE I’m trying to find Blaupunkt documentation for this amp but looks to be very poorly supported. What are the symptoms with the amp? The main thing that I can see from back panel online is that the remote (rem) terminal needs to have switched 12v to power the amp on. How do you have the amp and speakers wired? The amp just shuts down as soon as I accelerate the motor under load. 1st gear or second. It blips, and starts again 5 seconds later. Can’t really use it. The amp has a remote on connection, I installed it to the fuse board on a free tab that opens with the ignition on I understand. Have you measured the 12v power supply while the amp is shutting off? This would be just to make sure amp isn’t going past its 15v upper supply voltage limit. So just to clarify, if you don’t run the motor, the amp will work and keeps working OK until the engine is started? |
CCE |
@CCE I’m trying to find Blaupunkt documentation for this amp but looks to be very poorly supported. What are the symptoms with the amp? The main thing that I can see from back panel online is that the remote (rem) terminal needs to have switched 12v to power the amp on. How do you have the amp and speakers wired? The amp just shuts down as soon as I accelerate the motor under load. 1st gear or second. It blips, and starts again 5 seconds later. Can’t really use it. The amp has a remote on connection, I installed it to the fuse board on a free tab that opens with the ignition on I understand. Have you measured the 12v power supply while the amp is shutting off? This would be just to make sure amp isn’t going past its 15v upper supply voltage limit. Not yet, I will do as soon as I get home, I think will be up the chart. I was thinking on installing the “+” cable direct from the fuse bar, but worry it can be too much load on a 50 year old board… |
Lo-Fi Version | Time is now: 27th June 2024 - 07:59 PM |
