CCE |
CCE ![]() ![]() Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille ![]() ![]() |
Just installed a Bluetooth amp to my car, to clean the dashboard with a blank faceplate, I ran a cable direct to my battery but I am getting the amp to shut down protecting maybe because of an overload since it doesn’t get energy from the regulated board I think. Can anyone confirm if my assumption is correct or if my regulator is not regulating correctly.
Thanks. I updated the photo. And my wires ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,016 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
@CCE
So here are a couple things you can do: 1) clean off that under dash ground until you have shinny bare metal 1a) you can use a multimeter to measure resistance between that under dash ground and battery post negative to appease Ninja. Should be very close to zero ohms. Your test leads will have some resistance. Measure by shorting leads. Subtract that from whatever the meter reads between under dash and battery negative 2) use meter to monitor the 12v input to the amp while driving. Should not really be much above 14.5v max. Since you are tapped directly off battery positive this is your battery voltage when runnning and charging. If it’s exceeding 15v here, your voltage regulator is acting up. 3) monitor the remote connection when driving to make sure that it has a steady 12v being supplied to it. A loose spade connector on the fuse panel proving intermittent 12v would cause the shutdown / restart behavior you’re seeing. From what I can find for amp documentation the input voltage upper limit is 15v. Make sure you aren’t exceeding that. Beyond that it would be RF interference from old school ignition or alternator that the amp is sensitive to and causing the shutdowns. |
Lo-Fi Version | Time is now: 27th June 2024 - 08:29 PM |
