Bwingate |
Newbie ![]() Group: Members Posts: 19 Joined: 30-March 24 From: New York Member No.: 28,029 Region Association: North East States ![]() |
I have been fighting mushy brakes since I got my 914. They are better but not great. I suspect there is a lot more bleeding to do, including finding the proportioning valve to bleed.
The PO said that they had the master cylinder changed by a local "Porsche expert" I suspect it was replaced with the 17 mm master cylinder. Can I confirm with an external inspection whether it is a 17 mm or 19 mm MC? So my plan is: 1) Bleed MC 2) Bleed proportioning valve 3) Possible replace soft lines 4) Bleed each wheel again. I saw something on this site that made sense, but I had never seen it before: Clamp off all the soft lines and test the pedal. If the pedal is solid, then the problem is at the wheels; if the pedal is soft, then it is the MC. Then unclamp each wheel one at a time - the "bad" wheel will be soft, the "good" wheels will have a firm pedal. Is this a bad idea? |
friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 529 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
For me, I had air between the bleeders on the rear brakes ('74). Took me several iterations to get all out but after that, my peddle was great. Just took time. |
Lo-Fi Version | Time is now: 27th June 2024 - 11:43 PM |
