Me vs. Brakes: The Road to a Solid Pedal |
Bwingate |
May 20 2024, 07:25 AM
Newbie Group: Members Posts: 19 Joined: 30-March 24 From: New York Member No.: 28,029 Region Association: North East States |
I have been fighting mushy brakes since I got my 914. They are better but not great. I suspect there is a lot more bleeding to do, including finding the proportioning valve to bleed.
The PO said that they had the master cylinder changed by a local "Porsche expert" I suspect it was replaced with the 17 mm master cylinder. Can I confirm with an external inspection whether it is a 17 mm or 19 mm MC? So my plan is: 1) Bleed MC 2) Bleed proportioning valve 3) Possible replace soft lines 4) Bleed each wheel again. I saw something on this site that made sense, but I had never seen it before: Clamp off all the soft lines and test the pedal. If the pedal is solid, then the problem is at the wheels; if the pedal is soft, then it is the MC. Then unclamp each wheel one at a time - the "bad" wheel will be soft, the "good" wheels will have a firm pedal. Is this a bad idea? |
moto914 |
May 21 2024, 01:01 PM
Newbie Group: Members Posts: 49 Joined: 27-February 17 From: Greenville SC Member No.: 20,878 Region Association: South East States |
Get a pressure bleeder, best way to bleed the brakes. Replace the old brake lines first. Motiv pressure bleeder The nice thing about Motiv pressure bleeders is they will hold a pressure. You can go from one bleed point to the next. One thing to note; They pressurize at the brake fluid fill reservoir. The brake fluid fill reservoir should be only minimally pressurized. You can rig a Motiv pressure bleeder to connect to the caliper, and pressurize there also. (can handle more pressure there ) While pressurized some points of interest, can be slightly loosened and re-tightened to make sure only fluid escapes, and not air. (maybe at a high point where the soft and hard lines connect) |
Lo-Fi Version | Time is now: 28th September 2024 - 09:03 AM |
