CCE |
CCE ![]() ![]() Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille ![]() ![]() |
Just installed a Bluetooth amp to my car, to clean the dashboard with a blank faceplate, I ran a cable direct to my battery but I am getting the amp to shut down protecting maybe because of an overload since it doesn’t get energy from the regulated board I think. Can anyone confirm if my assumption is correct or if my regulator is not regulating correctly.
Thanks. I updated the photo. And my wires ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,997 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I went looking for the manual for this amp to see what the specs were and found these 1 star ratings on Amazon. Not saying anything about the product; just reading comments. Lots of unhappy people.
From the United States Lee S. 1.0 out of 5 stars Poor, Unsupported Product…That is defective. Reviewed in the United States on September 17, 2022 Verified Purchase Finally got around to installing this just to find out it will not power on. I double checked my input voltage and it was receiving 12 volts, but the unit is dead. The instructions are practically non-existent and provide no help whatsoever. If you do an internet search, there are several post about how the company doesn’t even have this listed under them. Just stay away from it. Absolute waste of money. Update…finally got it to work. Because the instructions are very poor and lacking in detail for install, it does not mention to wire ignition hot to the “rem” terminal to turnthe unit on. The sound is ok, but not loud when cranked up. Still not a recommendation. One person found this helpful Helpful Report BestTech 1.0 out of 5 stars Bad batch Reviewed in the United States on March 17, 2024 Verified Purchase I have bought and installed multiple of the “BT” version of this amp and love them. I put them in classic cars. Apparently the “BT” models are all gone and are now shipping the “BT PRO” only. So even though this listing doesnt say PRO , thats what you get. I have made 3 orders so far of this BTPRO model and each one has had the same issue , iphones wont connect and stay connected. It keeps dropping the Bluetooth immediately upon playing a song. Upon my return third bad unit I called Blaupunkt tech support and they said theres a bad batch if them and that I could mail my unit to them and they would send me an updated unit so thats what I am going to do. All three of my bad ones came from this amazon seller so unfortunately they probably have more of these bad ones which need to be returned to Blaupunkt. So if you plan to buy one , be prepared for it to potentially not work with iphone and need to return it or send it to the manufacturer. 2 people found this helpful Helpful Report mark 1.0 out of 5 stars 1 of 3 worked Reviewed in the United States on February 12, 2024 Verified Purchase Read entire review- So i had purchased one of these amps to use in a classic car- it worked flawlessly and connected everytime as soon as you turned the key to give the signal to pair with my iPhone/ i sold the car and the amp went with it I then got another car and i liked the amp so much i purchased another one- installed it and noticed it now read Amp1840btPRO in the Bluetooth settings- my first one did not have the pro in the title- it was having a hardtime connecting to my phone- when it did connect it would play audio for about 2 seconds and then drop the signal, i could not get it to play more than that- so i figured it was defective- i returned it and got another one- then replacement would would also only play for 2 seconds and then drop the bluetooth signal, super bummed as now i need to find another Bluetooth amp- i would not try a 3rd as something definitely changed since my first one- pretty much the new batches do not function correctly unfortunately 2 people found this helpful Helpful Report Michael Bowick 1.0 out of 5 stars Disappointed Reviewed in the United States on March 30, 2024 Verified Purchase The Bluetooth would not stay connected, and the amp continuously would cut off for no reason. I was highly disappointed in the product. There is no videos to help troubleshooting the issues nor anyway to get help on the issues. I would not recommend using this amp. Helpful Report shane e. 1.0 out of 5 stars HORRIBLE AMP!!! Reviewed in the United States on May 20, 2023 Verified Purchase Amp seemed ok out of the box...but quickly found it to be a huge piece of junk. the antenna wouldn't stay tight, if you turn it one direct or the other, the base nut unscrews and everything just flops around. This thing does not produce the power it claims, didn't expect the high numbers, but did atleast expect 50w x4. Bluetooth connected easy, and always worked...but the amp has some severe limitations. One day while trying to adjust the front speakers to actually produce sound from the amp it poped and shut off forever...i had maybe 10 hours of total use out of the amp...and it couldn't even push a pair of tweeters and 4x10's... I bought an alpine amp and and RCA to usb c cable and these speakers are quite nice now. Helpful Report Matt H. 1.0 out of 5 stars Bluetooth wouldn’t stay connected. Reviewed in the United States on December 17, 2023 Verified Purchase Bought it to install in a classic car and be able to pair my phone via Bluetooth. It would play less than 3 seconds and then disconnect and then reconnect. Antenna was connected and phone works on all other Bluetooth sources. Wasted time wiring this thing up for it not to work. Unimpressed to say the least. One person found this helpful Helpful Report Mike 1.0 out of 5 stars Drops Bluetooth within seconds of playing Reviewed in the United States on March 26, 2024 Verified Purchase Don’t buy this junk. Can’t return it Helpful Report Willee 1.0 out of 5 stars Defective when I got it Reviewed in the United States on February 2, 2022 Verified Purchase UPDATE July 2022:: Since I bought it last November 2021 and it was defective on arrival. I sent an email to the manufacturer with a copy of my receipt. So 8 months later they have Not sent an email or tried to contact me in any way. DO NOT BUY - NO WARRANTY!! It took a month before I got around to installing it when I noticed the bluetooth antenna mount was loose. Tried to tighten it up and was only twisting wires inside it instead. Powered up the amp after install and the left channel is out (yes I checked it). Then after running for just a minute it would shut off. So basically I got a amp that shorted out from the factory and it's too late to return this boat anchor! 2 people found this helpful Helpful Report Amazon Customer 1.0 out of 5 stars No bluetooth Reviewed in the United States on January 5, 2024 Verified Purchase Very disappointed . Bluetooth will not stay connected even with phone with phone beside Unit . Sending back !! One person found this helpful Helpful Report Chops101 1.0 out of 5 stars Not True BT stereo Reviewed in the United States on January 10, 2023 Verified Purchase This is not a bad amp for the price, but I needed to use it exclusively for the BT adapting feature as I use iPhone exclusively for music streaming in my classic car. While it pairs well, and the sound is plenty loud but not much bass, it is mono when BT paired. That was the deal breaker, it's mono. And I tested it / validated that aspect. Had to send it back and went with a separate BT adapter and separate amp. |
CCE |
I went looking for the manual for this amp to see what the specs were and found these 1 star ratings on Amazon. Not saying anything about the product; just reading comments. Lots of unhappy people. From the United States Lee S. 1.0 out of 5 stars Poor, Unsupported Product…That is defective. Reviewed in the United States on September 17, 2022 Verified Purchase Finally got around to installing this just to find out it will not power on. I double checked my input voltage and it was receiving 12 volts, but the unit is dead. The instructions are practically non-existent and provide no help whatsoever. If you do an internet search, there are several post about how the company doesn’t even have this listed under them. Just stay away from it. Absolute waste of money. Update…finally got it to work. Because the instructions are very poor and lacking in detail for install, it does not mention to wire ignition hot to the “rem” terminal to turnthe unit on. The sound is ok, but not loud when cranked up. Still not a recommendation. One person found this helpful Helpful Report BestTech 1.0 out of 5 stars Bad batch Reviewed in the United States on March 17, 2024 Verified Purchase I have bought and installed multiple of the “BT” version of this amp and love them. I put them in classic cars. Apparently the “BT” models are all gone and are now shipping the “BT PRO” only. So even though this listing doesnt say PRO , thats what you get. I have made 3 orders so far of this BTPRO model and each one has had the same issue , iphones wont connect and stay connected. It keeps dropping the Bluetooth immediately upon playing a song. Upon my return third bad unit I called Blaupunkt tech support and they said theres a bad batch if them and that I could mail my unit to them and they would send me an updated unit so thats what I am going to do. All three of my bad ones came from this amazon seller so unfortunately they probably have more of these bad ones which need to be returned to Blaupunkt. So if you plan to buy one , be prepared for it to potentially not work with iphone and need to return it or send it to the manufacturer. 2 people found this helpful Helpful Report mark 1.0 out of 5 stars 1 of 3 worked Reviewed in the United States on February 12, 2024 Verified Purchase Read entire review- So i had purchased one of these amps to use in a classic car- it worked flawlessly and connected everytime as soon as you turned the key to give the signal to pair with my iPhone/ i sold the car and the amp went with it I then got another car and i liked the amp so much i purchased another one- installed it and noticed it now read Amp1840btPRO in the Bluetooth settings- my first one did not have the pro in the title- it was having a hardtime connecting to my phone- when it did connect it would play audio for about 2 seconds and then drop the signal, i could not get it to play more than that- so i figured it was defective- i returned it and got another one- then replacement would would also only play for 2 seconds and then drop the bluetooth signal, super bummed as now i need to find another Bluetooth amp- i would not try a 3rd as something definitely changed since my first one- pretty much the new batches do not function correctly unfortunately 2 people found this helpful Helpful Report Michael Bowick 1.0 out of 5 stars Disappointed Reviewed in the United States on March 30, 2024 Verified Purchase The Bluetooth would not stay connected, and the amp continuously would cut off for no reason. I was highly disappointed in the product. There is no videos to help troubleshooting the issues nor anyway to get help on the issues. I would not recommend using this amp. Helpful Report shane e. 1.0 out of 5 stars HORRIBLE AMP!!! Reviewed in the United States on May 20, 2023 Verified Purchase Amp seemed ok out of the box...but quickly found it to be a huge piece of junk. the antenna wouldn't stay tight, if you turn it one direct or the other, the base nut unscrews and everything just flops around. This thing does not produce the power it claims, didn't expect the high numbers, but did atleast expect 50w x4. Bluetooth connected easy, and always worked...but the amp has some severe limitations. One day while trying to adjust the front speakers to actually produce sound from the amp it poped and shut off forever...i had maybe 10 hours of total use out of the amp...and it couldn't even push a pair of tweeters and 4x10's... I bought an alpine amp and and RCA to usb c cable and these speakers are quite nice now. Helpful Report Matt H. 1.0 out of 5 stars Bluetooth wouldn’t stay connected. Reviewed in the United States on December 17, 2023 Verified Purchase Bought it to install in a classic car and be able to pair my phone via Bluetooth. It would play less than 3 seconds and then disconnect and then reconnect. Antenna was connected and phone works on all other Bluetooth sources. Wasted time wiring this thing up for it not to work. Unimpressed to say the least. One person found this helpful Helpful Report Mike 1.0 out of 5 stars Drops Bluetooth within seconds of playing Reviewed in the United States on March 26, 2024 Verified Purchase Don’t buy this junk. Can’t return it Helpful Report Willee 1.0 out of 5 stars Defective when I got it Reviewed in the United States on February 2, 2022 Verified Purchase UPDATE July 2022:: Since I bought it last November 2021 and it was defective on arrival. I sent an email to the manufacturer with a copy of my receipt. So 8 months later they have Not sent an email or tried to contact me in any way. DO NOT BUY - NO WARRANTY!! It took a month before I got around to installing it when I noticed the bluetooth antenna mount was loose. Tried to tighten it up and was only twisting wires inside it instead. Powered up the amp after install and the left channel is out (yes I checked it). Then after running for just a minute it would shut off. So basically I got a amp that shorted out from the factory and it's too late to return this boat anchor! 2 people found this helpful Helpful Report Amazon Customer 1.0 out of 5 stars No bluetooth Reviewed in the United States on January 5, 2024 Verified Purchase Very disappointed . Bluetooth will not stay connected even with phone with phone beside Unit . Sending back !! One person found this helpful Helpful Report Chops101 1.0 out of 5 stars Not True BT stereo Reviewed in the United States on January 10, 2023 Verified Purchase This is not a bad amp for the price, but I needed to use it exclusively for the BT adapting feature as I use iPhone exclusively for music streaming in my classic car. While it pairs well, and the sound is plenty loud but not much bass, it is mono when BT paired. That was the deal breaker, it's mono. And I tested it / validated that aspect. Had to send it back and went with a separate BT adapter and separate amp. Thanks I red most of them, the biggest complaint was on a short delivery of power from 100w to some 65w x4, they lost a lot of power to the advertised data, which in my case was not an issue, and a gain from my old car stereo that was 40w per channel, just want to hear, not share with the neighbors. And also it connects really well to my iPhone, surprisingly well. So I just need to sort the problem which I think is in my power regulator, and we will do fine. ![]() |
CCE |
I went looking for the manual for this amp to see what the specs were and found these 1 star ratings on Amazon. Not saying anything about the product; just reading comments. Lots of unhappy people. From the United States Lee S. 1.0 out of 5 stars Poor, Unsupported Product…That is defective. Reviewed in the United States on September 17, 2022 Verified Purchase Finally got around to installing this just to find out it will not power on. I double checked my input voltage and it was receiving 12 volts, but the unit is dead. The instructions are practically non-existent and provide no help whatsoever. If you do an internet search, there are several post about how the company doesn’t even have this listed under them. Just stay away from it. Absolute waste of money. Update…finally got it to work. Because the instructions are very poor and lacking in detail for install, it does not mention to wire ignition hot to the “rem” terminal to turnthe unit on. The sound is ok, but not loud when cranked up. Still not a recommendation. One person found this helpful Helpful Report BestTech 1.0 out of 5 stars Bad batch Reviewed in the United States on March 17, 2024 Verified Purchase I have bought and installed multiple of the “BT” version of this amp and love them. I put them in classic cars. Apparently the “BT” models are all gone and are now shipping the “BT PRO” only. So even though this listing doesnt say PRO , thats what you get. I have made 3 orders so far of this BTPRO model and each one has had the same issue , iphones wont connect and stay connected. It keeps dropping the Bluetooth immediately upon playing a song. Upon my return third bad unit I called Blaupunkt tech support and they said theres a bad batch if them and that I could mail my unit to them and they would send me an updated unit so thats what I am going to do. All three of my bad ones came from this amazon seller so unfortunately they probably have more of these bad ones which need to be returned to Blaupunkt. So if you plan to buy one , be prepared for it to potentially not work with iphone and need to return it or send it to the manufacturer. 2 people found this helpful Helpful Report mark 1.0 out of 5 stars 1 of 3 worked Reviewed in the United States on February 12, 2024 Verified Purchase Read entire review- So i had purchased one of these amps to use in a classic car- it worked flawlessly and connected everytime as soon as you turned the key to give the signal to pair with my iPhone/ i sold the car and the amp went with it I then got another car and i liked the amp so much i purchased another one- installed it and noticed it now read Amp1840btPRO in the Bluetooth settings- my first one did not have the pro in the title- it was having a hardtime connecting to my phone- when it did connect it would play audio for about 2 seconds and then drop the signal, i could not get it to play more than that- so i figured it was defective- i returned it and got another one- then replacement would would also only play for 2 seconds and then drop the bluetooth signal, super bummed as now i need to find another Bluetooth amp- i would not try a 3rd as something definitely changed since my first one- pretty much the new batches do not function correctly unfortunately 2 people found this helpful Helpful Report Michael Bowick 1.0 out of 5 stars Disappointed Reviewed in the United States on March 30, 2024 Verified Purchase The Bluetooth would not stay connected, and the amp continuously would cut off for no reason. I was highly disappointed in the product. There is no videos to help troubleshooting the issues nor anyway to get help on the issues. I would not recommend using this amp. Helpful Report shane e. 1.0 out of 5 stars HORRIBLE AMP!!! Reviewed in the United States on May 20, 2023 Verified Purchase Amp seemed ok out of the box...but quickly found it to be a huge piece of junk. the antenna wouldn't stay tight, if you turn it one direct or the other, the base nut unscrews and everything just flops around. This thing does not produce the power it claims, didn't expect the high numbers, but did atleast expect 50w x4. Bluetooth connected easy, and always worked...but the amp has some severe limitations. One day while trying to adjust the front speakers to actually produce sound from the amp it poped and shut off forever...i had maybe 10 hours of total use out of the amp...and it couldn't even push a pair of tweeters and 4x10's... I bought an alpine amp and and RCA to usb c cable and these speakers are quite nice now. Helpful Report Matt H. 1.0 out of 5 stars Bluetooth wouldn’t stay connected. Reviewed in the United States on December 17, 2023 Verified Purchase Bought it to install in a classic car and be able to pair my phone via Bluetooth. It would play less than 3 seconds and then disconnect and then reconnect. Antenna was connected and phone works on all other Bluetooth sources. Wasted time wiring this thing up for it not to work. Unimpressed to say the least. One person found this helpful Helpful Report Mike 1.0 out of 5 stars Drops Bluetooth within seconds of playing Reviewed in the United States on March 26, 2024 Verified Purchase Don’t buy this junk. Can’t return it Helpful Report Willee 1.0 out of 5 stars Defective when I got it Reviewed in the United States on February 2, 2022 Verified Purchase UPDATE July 2022:: Since I bought it last November 2021 and it was defective on arrival. I sent an email to the manufacturer with a copy of my receipt. So 8 months later they have Not sent an email or tried to contact me in any way. DO NOT BUY - NO WARRANTY!! It took a month before I got around to installing it when I noticed the bluetooth antenna mount was loose. Tried to tighten it up and was only twisting wires inside it instead. Powered up the amp after install and the left channel is out (yes I checked it). Then after running for just a minute it would shut off. So basically I got a amp that shorted out from the factory and it's too late to return this boat anchor! 2 people found this helpful Helpful Report Amazon Customer 1.0 out of 5 stars No bluetooth Reviewed in the United States on January 5, 2024 Verified Purchase Very disappointed . Bluetooth will not stay connected even with phone with phone beside Unit . Sending back !! One person found this helpful Helpful Report Chops101 1.0 out of 5 stars Not True BT stereo Reviewed in the United States on January 10, 2023 Verified Purchase This is not a bad amp for the price, but I needed to use it exclusively for the BT adapting feature as I use iPhone exclusively for music streaming in my classic car. While it pairs well, and the sound is plenty loud but not much bass, it is mono when BT paired. That was the deal breaker, it's mono. And I tested it / validated that aspect. Had to send it back and went with a separate BT adapter and separate amp. Thanks I red most of them, the biggest complaint was on a short delivery of power from 100w to some 65w x4, they lost a lot of power to the advertised data, which in my case was not an issue, and a gain from my old car stereo that was 40w per channel, just want to hear, not share with the neighbors. And also it connects really well to my iPhone, surprisingly well. So I just need to sort the problem which I think is in my power regulator, and we will do fine. ![]() All connections ar good and tight, (I did the shake test as mentioned, thanks) I ordered a regulator from Autoatlanta, I don’t trust my regulator anymore, and regarding the amp specs. Here is a photo of the very poor brochure. ![]() |
Lo-Fi Version | Time is now: 30th June 2024 - 06:04 AM |
