neilbardsley |
Newbie ![]() Group: Members Posts: 43 Joined: 11-October 20 From: England Member No.: 24,754 Region Association: Europe ![]() |
https://www.ebay.co.uk/itm/165865762191?mkc...&media=COPY
Is this kit compatible with the type 4 filter? Seems like pretty easy add on? I would prefer a coupling that didn't use the external filter until 180f but can't find a complete kit. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
In my experience on the race track, continuous operating at oil temps much above 225F was detrimental to oil pressure. Not sure if it was change in viscosity or larger bearing clearances or some combination of the two.
neilbardsley |
In my experience on the race track, continuous operating at oil temps much above 225F was detrimental to oil pressure. Not sure if it was change in viscosity or larger bearing clearances or some combination of the two. This is to do with oil quality. The stability/viscosity index is only measured to 100c so it not a good measure of stability at higher temperatures. If you look at Motul's 300v racing oil they state the viscosity at 150c. I believe you want a figure above 4. This is where good modern synthetic oil will out performance a mineral. https://raceandrally.com/motul-300v-chrono-...g-engine-oil-2l |
Lo-Fi Version | Time is now: 27th June 2024 - 06:33 PM |
