thecleanoutking |
Newbie ![]() Group: Members Posts: 21 Joined: 8-May 24 From: Florida Member No.: 28,109 Region Association: South East States ![]() |
I was trying to get to the brake switch at the pedal to rule out any issues there..
Oh boy!! posted another thread yesterday (someone said it was a bit of a wiggle job) I'd say.. just to get to the two allens that hold the kick board i had to basically remove the carpet, half my console and after all that I still can't get the kick board out.. The carpet had holes for the clutch pedal, brake pedal, accelerator pedal and even a separate hole for the rod behind the gas pedal (which I ended up just putting a slice into that small hole or I might still be there).. Now still can't get the kick board out but I lifted it and after removing a small mouse nest i can barley see what I think is the switch...man.. Should have started with the switch at the master?? why two switches any advice on the kick board and pedal switch? ![]() ![]() ![]() |
Ishley |
Member ![]() ![]() Group: Members Posts: 109 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest ![]() ![]() |
There are four nuts. The ones in the floor and then you have to take the two off that hold the master cylinder on. Those are accessed from underneath after you remove the steering rack cover.
Lo-Fi Version | Time is now: 28th June 2024 - 04:59 AM |
