thecleanoutking |
Newbie ![]() Group: Members Posts: 21 Joined: 8-May 24 From: Florida Member No.: 28,109 Region Association: South East States ![]() |
I was trying to get to the brake switch at the pedal to rule out any issues there..
Oh boy!! posted another thread yesterday (someone said it was a bit of a wiggle job) I'd say.. just to get to the two allens that hold the kick board i had to basically remove the carpet, half my console and after all that I still can't get the kick board out.. The carpet had holes for the clutch pedal, brake pedal, accelerator pedal and even a separate hole for the rod behind the gas pedal (which I ended up just putting a slice into that small hole or I might still be there).. Now still can't get the kick board out but I lifted it and after removing a small mouse nest i can barley see what I think is the switch...man.. Should have started with the switch at the master?? why two switches any advice on the kick board and pedal switch? ![]() ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
There is only one switch that operates the brake lights and its under that pedal board. Here is a link to what it looks like. https://www.pelicanparts.com/More_Info/9116...CxoCGJcQAvD_BwE
The brake pedal pushes on that lever. To get the pedal board out, you have to push the clutch pedal down to get that side out and then you should be able to manipulate the brake pedal side out. You can also remove the pedal pads for a little more space. I agree with removing the pedals. Undo the two 13mm nuts and lift it up and out. It does come out as one piece. I would send the pedals to bdstone914 on the board and have him rebuild them. He did my pedals. http://www.914world.com/bbs2/index.php?showtopic=65920 |
thecleanoutking |
Thanks for good information I actually have a new switch just can't seem to locate the old one until I remove the kick board, will work on that in a bit, hot here in Florida, I was seeing two brake switches when I was looking up some parts.. one on the master but I haven't looked there yet was hesitant to pull that cover down from underneath I'm afraid as to what i might see..lol..only had the car a few weeks..
Pelican Parts There seems to be a rod on the back of the gas pedal will that come out with the assembly or is that another step? There is only one switch that operates the brake lights and its under that pedal board. Here is a link to what it looks like. https://www.pelicanparts.com/More_Info/9116...CxoCGJcQAvD_BwE The brake pedal pushes on that lever. To get the pedal board out, you have to push the clutch pedal down to get that side out and then you should be able to manipulate the brake pedal side out. You can also remove the pedal pads for a little more space. I agree with removing the pedals. Undo the two 13mm nuts and lift it up and out. It does come out as one piece. I would send the pedals to bdstone on the board and have him rebuild them. He did my pedals. |
Lo-Fi Version | Time is now: 28th June 2024 - 04:55 AM |
