Carb fire.. why? |
Carb fire.. why? |
H2ohs |
May 13 2024, 01:29 PM
Newbie Group: Members Posts: 15 Joined: 23-October 22 From: NH Member No.: 26,941 Region Association: North East States |
Hi All, took the car out of storage, cleaned, took for a 20 min ride. Was running great. 3 min from home, it started to run really rough. Not sure if it was on fire at this point, but barely made it home. got out and flames were shooting from the grid. Fire extinguisher was close, so put out pretty quickly. Rain tray melted and made a mess. The carb filter totally burned and destroyed. All fuel lines in good shape, no leaks. So what would make the carb catch on fire like this? float? timing? this pic is after trying to clean the fire extinguisher mess off- it still runs fine actually. Ideas?
peteinjp |
May 13 2024, 04:47 PM
Member Group: Members Posts: 205 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
How long was the car in storage? I’ve seen fuel lines weep after being in storage only to seal up after running a bit.
Pete |
JamesM |
May 22 2024, 05:17 PM
Senior Member Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
How long was the car in storage? I’ve seen fuel lines weep after being in storage only to seal up after running a bit. Pete (IMG:style_emoticons/default/agree.gif) Seen this a lot, especially with injector hoses. Though figured it wouldnt be such an issue on carbs with much lower fuel pressures. |
Lo-Fi Version | Time is now: 28th June 2024 - 04:46 AM |
