Factory 911 air cleaners, What fits what? |
mate914 |
May 6 2024, 04:29 PM
Matt Group: Members Posts: 802 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I recently picked up a 911 mechanical fuel injection, air cleaner assembly . I was hoping I could use this with the carburetor Air cleaner base unit I already have. I was wrong once again. Can anyone point me in the right direction on how to make this set up work? I have no problem making custom clips to attach to. Has anybody modified a plastic air cleaner to work with Zenith air cleaner base mounts.
Matt |
rgalla9146 |
May 10 2024, 06:48 AM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hey Matt What doesn't fit ? You have a 6 air filter, Zenith boats (same as Webers) and Weber carbs. When installing the stock air filter housing in the car it is a bit of a wiggle. Attaching the drain hose, the big vent hose and flipping a couple of the clips is annoying. Doesn't sound like any adaptation is necessary except for correct clips. |
mate914 |
May 25 2024, 11:58 AM
Hey Matt What doesn't fit ? You have a 6 air filter, Zenith boats (same as Webers) and Weber carbs. When installing the stock air filter housing in the car it is a bit of a wiggle. Attaching the drain hose, the big vent hose and flipping a couple of the clips is annoying. Doesn't sound like any adaptation is necessary except for correct clips. @rgalla9146 Thanks for your help. I can not find part numbers for the longer clips. Any idea what models used the metal bases and the plastic filter housing? Maybe just 9146 and the 911T of that years? Thanks Matt |
Lo-Fi Version | Time is now: 6th January 2025 - 07:06 PM |
