CCE |
CCE ![]() ![]() Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille ![]() ![]() |
Just installed a Bluetooth amp to my car, to clean the dashboard with a blank faceplate, I ran a cable direct to my battery but I am getting the amp to shut down protecting maybe because of an overload since it doesn’t get energy from the regulated board I think. Can anyone confirm if my assumption is correct or if my regulator is not regulating correctly.
Thanks. I updated the photo. And my wires ![]() |
CCE |
Just got a new hella regulator from Autoatlanta….
Magic. It now works perfectly my old regulator was allowing more power than it should.. It now sounds and moves at the same time. All suggestions where followed It’s a bit smaller in height but worked immediately now I need to figure out the retaining screws. But it is working. Previous one was from autozone apparently was not correct for the car. Had some issues with coils in the past. Car baked the CB performance dry coils. Thanks all ![]() |
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,892 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
Just got a new hella regulator from Autoatlanta…. Magic. It now works perfectly my old regulator was allowing more power than it should.. It now sounds and moves at the same time. All suggestions where followed It’s a bit smaller in height but worked immediately now I need to figure out the retaining screws. But it is working. Previous one was from autozone apparently was not correct for the car. Had some issues with coils in the past. Car baked the CB performance dry coils. Thanks all ![]() I'm glad the amp is good to go. It's much easier to replace the voltage regulator. We used to call the bad ones "Bosch Battery Bakers." You'll need some SS sheet metal screws to secure it. Be gentle & try not to cross thread or strip out the holes. Right on dude!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 05:51 AM |
