> Air Cleaner Insights, 914-6 Correct
DennisV
post May 29 2024, 11:00 AM
Is this air cleaner correct for 1970 914-6? Am I missing any components?
I went through the other air cleaner threads I could find. A couple things about our plastic one that seems curious when I compare it to the photos I'm finding of others identified as 914-6:
  1. No clips or inlets for cold start fuel lines
  2. Large to small outlet plastic fitting
Thanks.
P.S. I am unclear about the fittings. My best guess is the small single port metal one is a water drain valve and big plastic one with two outlets is oil breather? Not sure how to connect either.
gereed75
post May 29 2024, 10:25 PM
Six one has a plated metal vent connection.
DennisV   Air Cleaner Insights   May 29 2024, 11:00 AM
930cabman   :popcorn:   May 29 2024, 12:20 PM
rgalla9146   Not for a 6...for 911 w/mechanical fuel injection....   May 29 2024, 10:08 PM
DennisV   Not for a 6...for 911 w/mechanical fuel injection...   May 30 2024, 06:56 AM
DennisV   Not for a 6...for 911 w/mechanical fuel injection...   Jun 4 2024, 06:17 AM
gereed75   Six one has a plated metal vent connection.   May 29 2024, 10:25 PM
Superhawk996   Good luck on your quest Recent thread along same...   Jun 4 2024, 07:54 AM
930cabman   Is the air cleaner specific to a 914 6? I have a m...   Jun 4 2024, 08:20 AM
fixer34   Some pictures I have of mine. Cold start pipes are...   Jun 4 2024, 01:27 PM
930cabman   Thank you, is this an original setup as far as you...   Jun 4 2024, 01:38 PM
fixer34   Thank you, is this an original setup as far as yo...   Jun 6 2024, 11:30 AM
ClayPerrine   That air cleaner won't work with a 914-6. It ...   Jun 4 2024, 01:38 PM
930cabman   That air cleaner won't work with a 914-6. It...   Jun 4 2024, 02:05 PM
mb911   That air cleaner won't work with a 914-6. It...   Jun 4 2024, 04:29 PM
gereed75   Dennis V IMHO that is not a 914 box. It is a 911...   Jun 4 2024, 04:25 PM
DennisV   Dennis V all six boxes I have seen have the indi...   Jun 5 2024, 07:20 AM
gereed75   Sounds like Ben has tried this. I was assuming th...   Jun 4 2024, 04:48 PM
mb911   So the bucket have the brackets located at differe...   Jun 4 2024, 06:11 PM
gereed75   It’s always something. I guess the safe way is ...   Jun 4 2024, 08:21 PM
930cabman   It’s always something. I guess the safe way is...   Jun 5 2024, 08:58 AM
gereed75   Sure. the plastic one will fit and apparently the...   Jun 5 2024, 09:34 AM
930cabman   "sick old Porsche hobbyists" Well said   Jun 5 2024, 12:21 PM
rgalla9146   ....but wait...theres more ! please excuse...   Jun 5 2024, 06:08 PM
DennisV   ....but wait...theres more ! please excus...   Jun 6 2024, 04:21 PM
rgalla9146   Denis your inlet snorkel appears to be correct for...   Jun 5 2024, 06:43 PM
rgalla9146   Pic shows the larger clip and attachment to the bo...   Jun 5 2024, 07:11 PM
IronHillRestorations   I’ve read about a few cases of 6’s getting hyd...   Jun 5 2024, 07:45 PM
gereed75   Wow, great find on the metal drain tube fitting. I...   Jun 5 2024, 09:53 PM
gereed75   RE: Air Cleaner Insights   Jun 5 2024, 10:10 PM
gereed75   Wow we have beat this to death!   Jun 5 2024, 10:12 PM
DennisV   Wow we have beat this to death! Perhaps, but...   Jun 6 2024, 05:01 PM
930cabman   But there's more Clearance is very tight h...   Jun 6 2024, 04:55 AM
gereed75   But there's more Clearance is very tight ...   Jun 6 2024, 07:26 AM
930cabman   But there's more Clearance is very tight ...   Jun 6 2024, 10:24 AM
mb911   We need Glenn Stazek to chime in. He would be what...   Jun 6 2024, 05:22 AM
rgalla9146   K&N rain hats fit on my stock 6 no problem. ...   Jun 6 2024, 09:36 AM
- Lo-Fi Version Time is now: 6th January 2025 - 06:47 PM
