123 Distributor Install - post-mortum, MPS was “bad”? But it isn’t? |
FlacaProductions |
May 12 2024, 10:14 AM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Many of you followed and helped as I attempted to install a bluetooth 123 distributor in my 74 2.0 here:
http://www.914world.com/bbs2/index.php?sho...=368374&hl= I can’t thank everyone enough for all of their input. Car originally ran pretty well but I was installing the 123 to fix a running-warm situation due to a failed vacuum can on the stock distributor. (0231174011 with Pertronix Igniter II) MPS was a clearly opened/modified 0280100041 (done by PO). The install proved difficult/frustrating (would NOT start) and everything from a bad 123 unit to not accurately finding TDC was suspected. Luckily, I had recently picked up a stock/unopened 0280100043 MPS and after installing and re-installing the 123 multiple times, confirming TDC, etc, etc, I was desperate. I know you’re not supposed to just “throw” parts at a problem, but in a last-ditch effort I dropped in the “new” 043 MPS and it immediately fired up. Runs GREAT. This is where things get confusing: The 041 tests ok out of the car - 15lbs of vac for 30 mins and I get 95 ohms across 7 and 15 and 345 ohms across 8 and 10. The 041 had obviously been opened and I assume modified/repaired - but again - it ran fine in conjunction with the stock distributor w/Pertronix. Why would it run just “fine” (outside of the conditions caused by the failed distributor vacuum can) with the stock distributor/041 MPS and yet not even come close to starting with the 123/041 combo, and then run great with the 123/043 setup? Now i’m on to dialing in/playing with curves - I’ve found really nice performance with one that Pete Stout posted. Even though his is a 1.8, it made a noticeable difference to the point where my nephew remarked that it was really “snappy” now. Other than that, I think i’m going to pop the 2 female pins out of the wiring harness that the 123 yellow and white wires plug into and shrink wrap them for a more solid connection. That seems like a weak link. Additional questions: - does my original distributor with Pertronix have value to anyone? The Pertronix itself is $100+ new. I can’t see needing to keep it as a backup when the vacuum can has tested bad and the 123’s are seemingly bulletproof once properly installed. - does my 041 MPS have value? Should I open it up or have it tested and potentially rebuilt? As it sits, it totally immobilizes my 914 when installed. Is there potential to have it turned into a viable backup? Again - thanks to The World. I learned a lot during this process and could NOT have gotten to the other side without all the input here! |
Superhawk996 |
Jun 1 2024, 01:33 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Appreciate the update. That helps make some sense of this.
I think one of the biggest issues that face all of us is that of false assumptions. In my career of 40+ years of troubleshooting both electronics and mechanical systems, false assumptions cause the most problems and are the largest waste of time. Early on in USAF tech school we were taught to troubleshoot by starting with a “de-brief” of what the situation was, symptoms, tests done, etc. Basics were to re-verify what you were told before starting your own troubleshooting. If you immediately started trouble shooting based off the information given - you would be intentionally led astray and would fail the exercise either by coming to the wrong root cause conclusion or by simply running out of time chasing your tail thinking something you were told was true or had been verified and trying to make sense of conflicting symptoms. The long screw serves as a brilliant example of how this happens. A good lesson for all of us to heed. |
Lo-Fi Version | Time is now: 19th September 2024 - 10:21 AM |
