Marcel Aircooled |
Newbie ![]() Group: Members Posts: 41 Joined: 28-April 24 From: The Netherlands Member No.: 28,087 Region Association: Europe ![]() |
My 1973 914 with 2.0 liter 1974 GA engine came with a non original combined temp and oil pressure gauge. At first glance it looks like a normal VDO gauge, maybe for 911 original but looking closer it seems the letters and numbers are hand painted or some sort of transfer decals. There is no item number and at the back there is also no number or date stamp. Could this be custom made by someone? Here are some pictures
![]() ![]() ![]() This is the sensor that is installed ![]() The temp meter works but the pressure meter works only from time to time and sometimes drops all the way down or jumps up to the maximum. I took it out and replaced it with an original fuel gauge with just the pressure warning light and a 60mm temp gauge in the console. Maybe someone can tell me more about this gauge? |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,606 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
This is a 1970-71 911 oil gauge. 1969 was very similar in design but without that vertical symbol at the top, which gives it a nicer look (personal opinion (IMG:style_emoticons/default/biggrin.gif) )
Like the 70-73 914 gauges, 911 gauges had silver dot from their first appearance in 69 (black) until the switch in style in 74 both on the 911 and 914s. Not sure why you guys are saying this is custom. Seems to me it’s just in need of nice restoration. (IMG:style_emoticons/default/smile.gif) I personally think it is a nice addition to the 914 dash but it does require a separate fuel gauge. Edit: also important to know is that the dual sender low pressure is set higher that the stock sender, hence probably why you get that flicking light at idle. I forget the numbers but it’s documented here on 914World. (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 07:07 PM |
