FS: 19mm Front Sway Bar, SOLD |
Montreal914 |
May 10 2024, 07:42 PM
Senior Member Group: Members Posts: 1,671 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Please completely read the add.
For sale, H&H 19mm sway bar set that comes with: - Freshly powder coated 19mm bar (note damage near one end (IMG:style_emoticons/default/dry.gif) ). - H&H freshly plated flanges without bushings. Note that the bolt pattern of these flanges is slightly off vs stock flanges. To mount on stock sway bar body location, the holes of the H&H flanges will need to be slightly elongated (that is why I am providing these below). - Set of freshly plated stock flanges. - Set of new 911 turbo stock sway bar rubber bushings (18mm) should fit the 19mm bar with stock flanges (may need to make a cut, was told these should work, didn't want to open the bag). - Set of freshly plated H&H arms - Set of used Heim joint adjustable drop links (notice the uneven length... (IMG:style_emoticons/default/dry.gif) ) - Fresh Belmetric hardware. Price: |
Montreal914 |
Jun 3 2024, 01:34 PM
(IMG:style_emoticons/default/icon_bump.gif) with small price drop...
Also adding more parts I found: Set of used 19mm Weltmeister hard bushings. And set of stock freshly powder coated drop links. So, in recap, everything pictured in this thread for $300. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th September 2024 - 07:00 PM |
