Shifter "centering" and accidental reverse, Update - fixed |
burlybryan |
Jun 3 2024, 03:57 PM
Member Group: Members Posts: 117 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Since I've had my car (2020), it's always had a tendency to go from first straight up to reverse when shifting. Especially when cold. I've done all bushings from the firewall back, but I still have to be very careful when shifting from first to second. Shift from first requires a push out of first to let the shifter try to center, then carefully go up to second.
I haven't made any improvements to the shifter at the cabin. Are there similar bushings or a "centering spring" or something under the shifter than can be changed? All the focus seems to be on the firewall back, but I wondered if there is anything to prevent my reverse kiss tendencies at the shifter instead (besides the shiftee - me). Thanks. |
rhodyguy |
Jun 4 2024, 08:21 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Item #2 must be inspected for wear at the shift lever connection point along with the lever itself. The linkage should jump out of the 1st/R plane. If not done, presume EVERY bushing in the linkage needs replacement. Repeated grinding will more than likely result in an expensive repair and excessive down time. Shifter removal and inspection is a simple task.
Lo-Fi Version | Time is now: 18th September 2024 - 07:20 PM |
