> Air Cleaner Insights, 914-6 Correct
DennisV
post May 29 2024, 11:00 AM
Is this air cleaner correct for 1970 914-6? Am I missing any components?
I went through the other air cleaner threads I could find. A couple things about our plastic one that seems curious when I compare it to the photos I'm finding of others identified as 914-6:
  1. No clips or inlets for cold start fuel lines
  2. Large to small outlet plastic fitting
Thanks.
P.S. I am unclear about the fittings. My best guess is the small single port metal one is a water drain valve and big plastic one with two outlets is oil breather? Not sure how to connect either.
gereed75
post Jun 4 2024, 04:25 PM
Dennis V
IMHO that is not a 914 box. It is a 911 box. The snorkel appears to be correct six but there are some 911 snorkels that go to the same side (congrats either way, these are very difficult to find).
Having said that, there is no reason that you could not use that box for 914-6. You will need the correct carburetor buckets with the long version clips as shown in the thread linked above , post #7. You will have to drill holes between the stack holes for the Weber vents.
Hate to disagree with anyone as esteemed, learned and gentlemanly as Clay, but all six boxes I have seen have the individual stack holes as shown by Fixer above.
The bottom single vent is a gas /water drain but not sure if there is a vent hose attached or where it drains to (my foggy memory way back to my first six seems to recall it did indeed have a hose attached, might be wrong there, but seems likely).
The tee fitting large diameter side accepts a hose from the oil tank vent. no idea where the opposite side smaller connection goes to (on 911 applications the small diameter vent connection goes to the charcoal filter). I have an original six box where that smaller fitting is plugged, but have no way to know if that is correct. Can't think of any where that it might hook to on a six motor but who knows??
hope that helps
DennisV   Air Cleaner Insights   May 29 2024, 11:00 AM
930cabman   :popcorn:   May 29 2024, 12:20 PM
rgalla9146   Not for a 6...for 911 w/mechanical fuel injection....   May 29 2024, 10:08 PM
DennisV   Not for a 6...for 911 w/mechanical fuel injection...   May 30 2024, 06:56 AM
DennisV   Not for a 6...for 911 w/mechanical fuel injection...   Jun 4 2024, 06:17 AM
gereed75   Six one has a plated metal vent connection.   May 29 2024, 10:25 PM
Superhawk996   Good luck on your quest Recent thread along same...   Jun 4 2024, 07:54 AM
930cabman   Is the air cleaner specific to a 914 6? I have a m...   Jun 4 2024, 08:20 AM
fixer34   Some pictures I have of mine. Cold start pipes are...   Jun 4 2024, 01:27 PM
930cabman   Thank you, is this an original setup as far as you...   Jun 4 2024, 01:38 PM
fixer34   Thank you, is this an original setup as far as yo...   Jun 6 2024, 11:30 AM
ClayPerrine   That air cleaner won't work with a 914-6. It ...   Jun 4 2024, 01:38 PM
930cabman   That air cleaner won't work with a 914-6. It...   Jun 4 2024, 02:05 PM
mb911   That air cleaner won't work with a 914-6. It...   Jun 4 2024, 04:29 PM
gereed75   Dennis V IMHO that is not a 914 box. It is a 911...   Jun 4 2024, 04:25 PM
DennisV   Dennis V all six boxes I have seen have the indi...   Jun 5 2024, 07:20 AM
gereed75   Sounds like Ben has tried this. I was assuming th...   Jun 4 2024, 04:48 PM
mb911   So the bucket have the brackets located at differe...   Jun 4 2024, 06:11 PM
gereed75   It’s always something. I guess the safe way is ...   Jun 4 2024, 08:21 PM
930cabman   It’s always something. I guess the safe way is...   Jun 5 2024, 08:58 AM
gereed75   Sure. the plastic one will fit and apparently the...   Jun 5 2024, 09:34 AM
930cabman   "sick old Porsche hobbyists" Well said   Jun 5 2024, 12:21 PM
rgalla9146   ....but wait...theres more ! please excuse...   Jun 5 2024, 06:08 PM
DennisV   ....but wait...theres more ! please excus...   Jun 6 2024, 04:21 PM
rgalla9146   Denis your inlet snorkel appears to be correct for...   Jun 5 2024, 06:43 PM
rgalla9146   Pic shows the larger clip and attachment to the bo...   Jun 5 2024, 07:11 PM
IronHillRestorations   I’ve read about a few cases of 6’s getting hyd...   Jun 5 2024, 07:45 PM
gereed75   Wow, great find on the metal drain tube fitting. I...   Jun 5 2024, 09:53 PM
gereed75   RE: Air Cleaner Insights   Jun 5 2024, 10:10 PM
gereed75   Wow we have beat this to death!   Jun 5 2024, 10:12 PM
DennisV   Wow we have beat this to death! Perhaps, but...   Jun 6 2024, 05:01 PM
930cabman   But there's more Clearance is very tight h...   Jun 6 2024, 04:55 AM
gereed75   But there's more Clearance is very tight ...   Jun 6 2024, 07:26 AM
930cabman   But there's more Clearance is very tight ...   Jun 6 2024, 10:24 AM
mb911   We need Glenn Stazek to chime in. He would be what...   Jun 6 2024, 05:22 AM
rgalla9146   K&N rain hats fit on my stock 6 no problem. ...   Jun 6 2024, 09:36 AM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 07:23 PM
