Air Cleaner Insights, 914-6 Correct |
DennisV |
May 29 2024, 11:00 AM
Senior Member Group: Members Posts: 579 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Is this air cleaner correct for 1970 914-6? Am I missing any components?
I went through the other air cleaner threads I could find. A couple things about our plastic one that seems curious when I compare it to the photos I'm finding of others identified as 914-6:
Thanks. P.S. I am unclear about the fittings. My best guess is the small single port metal one is a water drain valve and big plastic one with two outlets is oil breather? Not sure how to connect either. |
ClayPerrine |
Jun 4 2024, 01:38 PM
Life's been good to me so far..... Group: Admin Posts: 15,969 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That air cleaner won't work with a 914-6. It uses clips that are attached to the MFI stacks. The 914-6 uses metal buckets with the clips that bolt to the carbs.
The six air cleaner doesn't have the individual holes for the stacks either. |
mb911 |
Jun 4 2024, 04:29 PM
914 Guru Group: Members Posts: 7,391 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That air cleaner won't work with a 914-6. It uses clips that are attached to the MFI stacks. The 914-6 uses metal buckets with the clips that bolt to the carbs. The six air cleaner doesn't have the individual holes for the stacks either. (IMG:style_emoticons/default/agree.gif) That is my experience as well. If someone has something different it is probably because it was swapped out at some point for the MFI housing |
Lo-Fi Version | Time is now: 6th January 2025 - 07:24 PM |
