FS: 19mm Front Sway Bar, SOLD |
Montreal914 |
May 10 2024, 07:42 PM
Senior Member Group: Members Posts: 1,671 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Please completely read the add.
For sale, H&H 19mm sway bar set that comes with: - Freshly powder coated 19mm bar (note damage near one end (IMG:style_emoticons/default/dry.gif) ). - H&H freshly plated flanges without bushings. Note that the bolt pattern of these flanges is slightly off vs stock flanges. To mount on stock sway bar body location, the holes of the H&H flanges will need to be slightly elongated (that is why I am providing these below). - Set of freshly plated stock flanges. - Set of new 911 turbo stock sway bar rubber bushings (18mm) should fit the 19mm bar with stock flanges (may need to make a cut, was told these should work, didn't want to open the bag). - Set of freshly plated H&H arms - Set of used Heim joint adjustable drop links (notice the uneven length... (IMG:style_emoticons/default/dry.gif) ) - Fresh Belmetric hardware. Price: |
technicalninja |
Jun 4 2024, 10:21 AM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
This set up will be stiff!
The stock bar is 15/16mm?? The adjustable linkage may help. Koozy is right! Ideal for auto crossing means pretty stiff for road use. The normal "application" is a prepared car with aftermarket bushings (read HARD) and higher rate torsion bars (like 911 stuff). Big tires/big brakes... If you were looking for this level of bar new it would be expensive! Montreal914 is a good guy. These are cheap enough that even I'm tempted. You can probably always be able to re-sell these at this price. The reason no-one has hit them yet is the fact they are at the top 20% of rates that work in in a 914. I'd correct the adjustable link length and sell the extra restored drops. I'm tempted (IMG:style_emoticons/default/devil.gif) If they were 17s they would be GONE! I (or someone else) would have snapped them up first day. If you've got a serious car this might be the ticket. Please buy them so I'm not tempted anymore... The little "digs" in the bar would not bother me at all. I wouldn't accept them in a brand-new bar (probably 1K) but these are NICE, and the plating is beautiful. I thought about buying them for the hardware alone. The adjustable position arms should have been done by the factory IMO. |
Montreal914 |
Jun 4 2024, 06:04 PM
This reply will be a lot shorter (IMG:style_emoticons/default/biggrin.gif)
The stock bar is 15/16mm?? -> 15mm Montreal914 is a good guy. Thanks! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 18th September 2024 - 07:15 PM |
