Air Cleaner Insights, 914-6 Correct |
DennisV |
May 29 2024, 11:00 AM
Senior Member Group: Members Posts: 579 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Is this air cleaner correct for 1970 914-6? Am I missing any components?
I went through the other air cleaner threads I could find. A couple things about our plastic one that seems curious when I compare it to the photos I'm finding of others identified as 914-6:
Thanks. P.S. I am unclear about the fittings. My best guess is the small single port metal one is a water drain valve and big plastic one with two outlets is oil breather? Not sure how to connect either. |
gereed75 |
Jun 4 2024, 08:21 PM
Senior Member Group: Members Posts: 1,320 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
It’s always something. I guess the safe way is to get the correct buckets, no raised inner wall.
Guess that’s why there are a variety of clamp sizes. Now looking more closely at Rory's pictures, it does appear that there is a slight difference in the height of the clip mounts between the the higher inner wall bucket and the correct one with even height walls. Either way the higher inner wall one will not fully seat down into a plastic box, therefore the clip distance is different and the rubber seals never seat onto the box body. Until looking with this much detail, never knew the differences, Guess I was just lucky when I bought the buckets at hershey and got the right ones. |
930cabman |
Jun 5 2024, 08:58 AM
Advanced Member Group: Members Posts: 3,806 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
It’s always something. I guess the safe way is to get the correct buckets, no raised inner wall. Guess that’s why there are a variety of clamp sizes. Especially with /6 conversion, the number of details appears never ending. I am not even going to try and calculate the hours I have into this /6 conversion, all I can say is many many From what I can tell there is no air filter that will fit between #3 carb and the trunk wall, very small clearance |
Lo-Fi Version | Time is now: 6th January 2025 - 07:35 PM |
