Shifter "centering" and accidental reverse, Update - fixed |
burlybryan |
Jun 3 2024, 03:57 PM
Member Group: Members Posts: 117 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Since I've had my car (2020), it's always had a tendency to go from first straight up to reverse when shifting. Especially when cold. I've done all bushings from the firewall back, but I still have to be very careful when shifting from first to second. Shift from first requires a push out of first to let the shifter try to center, then carefully go up to second.
I haven't made any improvements to the shifter at the cabin. Are there similar bushings or a "centering spring" or something under the shifter than can be changed? All the focus seems to be on the firewall back, but I wondered if there is anything to prevent my reverse kiss tendencies at the shifter instead (besides the shiftee - me). Thanks. |
rhodyguy |
Jun 5 2024, 08:58 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If #2 is spent and the underside of the shifter is loaded with gunk, adding extra springs is not going to solve the grinding problem. Increasing the force required to get into 1/R simply grinds more on the contact point. Odds are parts are worn and the bottom side of the shifter and springs are a greasy gritty mess. Adding additional and stiffer springs is not the solution.
Lo-Fi Version | Time is now: 18th September 2024 - 06:16 PM |
