> Air Cleaner Insights, 914-6 Correct
DennisV
post May 29 2024, 11:00 AM
Is this air cleaner correct for 1970 914-6? Am I missing any components?
I went through the other air cleaner threads I could find. A couple things about our plastic one that seems curious when I compare it to the photos I'm finding of others identified as 914-6:
  1. No clips or inlets for cold start fuel lines
  2. Large to small outlet plastic fitting
Thanks.
P.S. I am unclear about the fittings. My best guess is the small single port metal one is a water drain valve and big plastic one with two outlets is oil breather? Not sure how to connect either.
IronHillRestorations
post Jun 5 2024, 07:45 PM
I. I. R. C.
I’ve read about a few cases of 6’s getting hydro locked due to rain water getting past the seal and into the buckets.
gereed75
post Jun 5 2024, 09:53 PM
Wow, great find on the metal drain tube fitting. I vaguely remember seeing or having one of those but had no idea what it was for. That is some obscure minutiae right there! As is the Shell sticker insight!
I agree the clip on the back was to secure the cold start cross connection hose. See below. Also note on this box the what I think are correct cold start hose clamps. And also the plug in my vent fitting appears to match perfectly with the one Rory shows. Also see the same height walls on the plastic compatible buckets. These buckets work on carbs and the mag stack MFI as shown in the other photo.
The one other piece of obscure minutiae is the inclusion of the “fire screen” in the vent fitting that is pictured below on what I believe is a 911 MFI plastic box. And seems to appear on the six box Rory shows. This screen is not there on my six box? Maybe just missing.
By the way, the six box and this 911 MFI box are identical. Only the snorkels are different. There certainly are 911 plastic boxes with slight variations (indentations on the bottom) but the basic boxes are identical in shape form and ( I suspect) function.
Oh and found the link to this very comprehensive discussion on Early S Registry. https://www.early911sregistry.org/forums/sh...rious-MFI-years
gereed75
post Jun 5 2024, 10:10 PM
gereed75
post Jun 5 2024, 10:12 PM
Wow we have beat this to death!
DennisV   Air Cleaner Insights   May 29 2024, 11:00 AM
930cabman   :popcorn:   May 29 2024, 12:20 PM
rgalla9146   Not for a 6...for 911 w/mechanical fuel injection....   May 29 2024, 10:08 PM
DennisV   Not for a 6...for 911 w/mechanical fuel injection...   May 30 2024, 06:56 AM
DennisV   Not for a 6...for 911 w/mechanical fuel injection...   Jun 4 2024, 06:17 AM
gereed75   Six one has a plated metal vent connection.   May 29 2024, 10:25 PM
Superhawk996   Good luck on your quest Recent thread along same...   Jun 4 2024, 07:54 AM
930cabman   Is the air cleaner specific to a 914 6? I have a m...   Jun 4 2024, 08:20 AM
fixer34   Some pictures I have of mine. Cold start pipes are...   Jun 4 2024, 01:27 PM
930cabman   Thank you, is this an original setup as far as you...   Jun 4 2024, 01:38 PM
fixer34   Thank you, is this an original setup as far as yo...   Jun 6 2024, 11:30 AM
ClayPerrine   That air cleaner won't work with a 914-6. It ...   Jun 4 2024, 01:38 PM
930cabman   That air cleaner won't work with a 914-6. It...   Jun 4 2024, 02:05 PM
mb911   That air cleaner won't work with a 914-6. It...   Jun 4 2024, 04:29 PM
gereed75   Dennis V IMHO that is not a 914 box. It is a 911...   Jun 4 2024, 04:25 PM
DennisV   Dennis V all six boxes I have seen have the indi...   Jun 5 2024, 07:20 AM
gereed75   Sounds like Ben has tried this. I was assuming th...   Jun 4 2024, 04:48 PM
mb911   So the bucket have the brackets located at differe...   Jun 4 2024, 06:11 PM
gereed75   It’s always something. I guess the safe way is ...   Jun 4 2024, 08:21 PM
930cabman   It’s always something. I guess the safe way is...   Jun 5 2024, 08:58 AM
gereed75   Sure. the plastic one will fit and apparently the...   Jun 5 2024, 09:34 AM
930cabman   "sick old Porsche hobbyists" Well said   Jun 5 2024, 12:21 PM
rgalla9146   ....but wait...theres more ! please excuse...   Jun 5 2024, 06:08 PM
DennisV   ....but wait...theres more ! please excus...   Jun 6 2024, 04:21 PM
rgalla9146   Denis your inlet snorkel appears to be correct for...   Jun 5 2024, 06:43 PM
rgalla9146   Pic shows the larger clip and attachment to the bo...   Jun 5 2024, 07:11 PM
IronHillRestorations   I’ve read about a few cases of 6’s getting hyd...   Jun 5 2024, 07:45 PM
gereed75   Wow, great find on the metal drain tube fitting. I...   Jun 5 2024, 09:53 PM
gereed75   RE: Air Cleaner Insights   Jun 5 2024, 10:10 PM
gereed75   Wow we have beat this to death!   Jun 5 2024, 10:12 PM
DennisV   Wow we have beat this to death! Perhaps, but...   Jun 6 2024, 05:01 PM
930cabman   But there's more Clearance is very tight h...   Jun 6 2024, 04:55 AM
gereed75   But there's more Clearance is very tight ...   Jun 6 2024, 07:26 AM
930cabman   But there's more Clearance is very tight ...   Jun 6 2024, 10:24 AM
mb911   We need Glenn Stazek to chime in. He would be what...   Jun 6 2024, 05:22 AM
rgalla9146   K&N rain hats fit on my stock 6 no problem. ...   Jun 6 2024, 09:36 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 07:06 PM
