MPS Mapping, How and what info do you want? |
FlacaProductions |
May 30 2024, 01:06 PM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Many of you may remember my 123 Distributor install that finally worked out.
(here: http://www.914world.com/bbs2/index.php?sho...370332&hl=) I now have a vacuum pump and multi meter - TELL ME WHAT YOU WANT TO SEE. Unit is an 041 and has obviously been cracked open - before my time. It's marked with a Sharpie "74-76 2.0" which I believe is incorrect and should be for a 71-72 1.7. Maybe this accounts for the opening and potential adjustment. Currently holds 15in pretty much indefinitely and I get 93ohms between pins 7 and 15, and 344ohms between pins 8 and 10. All that seems pretty much right on - but it would NOT start after putting in the 123. Prior to the 123, it ran "fine" but then started running warm due to a distributor vacuum issue (more in another thread) Distributor was an 011 with a Pertronix Igniter II. Installed a "correct" 043 MPS and it fired right up and works great with the 123. Honestly - I'm just looking to acquire some database info for the World and then move this on, so if someone wants it, just yell. I have no idea what it's worth. |
rjames |
Jun 6 2024, 01:31 PM
I'm made of metal Group: Members Posts: 4,110 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
The results are in. I took readings using the same model Meterman LCR55 that Anders documented that he used for his measurements. I've adjusted Anders' measurements to reflect the altitude at my house.
As Flaca noted, his MPS has the following part #s stamped on it: Bosch 0 280 100 041 VW 022 906 051 E Anders' web site doesn't show an entry for x041, but does show 022 906 051 E, which on Anders' site is associated with Bosch 0 280 100 049 (designed for a '70-'73 1.7 liter). I haven't opened up the MPS (which has been opened before) but I'm guessing that it doesn't have the spacer that's in the 2.0 liter MPS. Flaca's MPS Compared with Anders' readings for a 2 liter x043 MPS and a 1.7 x049 mps which matches the same VW part # on Flaca's MPS (The chart uses only the 3 inHg data points that Anders provides.) |
Lo-Fi Version | Time is now: 18th September 2024 - 06:57 PM |
