MPS Mapping, How and what info do you want? |
FlacaProductions |
May 30 2024, 01:06 PM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Many of you may remember my 123 Distributor install that finally worked out.
(here: http://www.914world.com/bbs2/index.php?sho...370332&hl=) I now have a vacuum pump and multi meter - TELL ME WHAT YOU WANT TO SEE. Unit is an 041 and has obviously been cracked open - before my time. It's marked with a Sharpie "74-76 2.0" which I believe is incorrect and should be for a 71-72 1.7. Maybe this accounts for the opening and potential adjustment. Currently holds 15in pretty much indefinitely and I get 93ohms between pins 7 and 15, and 344ohms between pins 8 and 10. All that seems pretty much right on - but it would NOT start after putting in the 123. Prior to the 123, it ran "fine" but then started running warm due to a distributor vacuum issue (more in another thread) Distributor was an 011 with a Pertronix Igniter II. Installed a "correct" 043 MPS and it fired right up and works great with the 123. Honestly - I'm just looking to acquire some database info for the World and then move this on, so if someone wants it, just yell. I have no idea what it's worth. |
brant |
Jun 6 2024, 02:00 PM
914 Wizard Group: Members Posts: 11,726 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The diaphragm is berriliym-copper alloy
As replicated by Chris at CFR An AFR is the only way to tune The gasoline formulas are different than the gasoline available when the cars were built |
rjames |
Jun 6 2024, 02:05 PM
I'm made of metal Group: Members Posts: 4,110 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
The diaphragm is berriliym-copper alloy As replicated by Chris at CFR An AFR is the only way to tune The gasoline formulas are different than the gasoline available when the cars were built I fully agree that an AFR is needed to tune. An LCR meter is not needed at all if you know how to set the inner screw properly. What I don't think we know in this case is who rebuilt this particular MPS, if the diaphragm was ever replaced, and if so, what was used? My understanding is that before Chris made the beryllium ones people had tried using other materials, or even 'patching' the original diaphragms. We also don't know if the 2.0 spacer is in it. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:06 PM |
