Why did the 1.8 engines have L-jet? |
VaccaRabite |
May 31 2024, 08:05 AM
En Garde! Group: Admin Posts: 13,571 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Has there ever been a reason Porsche/VW speced L-jet injection for the 1.8 engines instead of D-jet like the 1.7 and 2.0 engines used?
Usually when manufactures do this there are financial reasons for the change. Either they have the same engine on other vehicles they produce, or its just cheaper to use whatever part is being used. But Porsche didn't use the T4 motor on other cars at the time. And if it was cheaper, they would have done away with Djet on the 1.7 and 2.0. I don't think VW was using l-let at the time for the bus... but maybe? There has to be a reason that Porsche wanted Ljet on the 1.8. Zach |
mrholland2 |
Jun 4 2024, 10:06 AM
Senior Member Group: Members Posts: 760 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
So if this was the case:
i suspect that no matter what D jet hit the wall emissions wise by 75. the 76s never met 76 emissions standards and certification. were sold as 76 model year but under the certification regime were classed as 75s if manufacture ceased by end of calendar year 1975 - which they did. Why are 76 914s subject to smog testing in CA? I mean, they should only have to meet the 1975 standards which is no smogging. |
wonkipop |
Jun 4 2024, 11:09 PM
Advanced Member Group: Members Posts: 4,658 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
So if this was the case: i suspect that no matter what D jet hit the wall emissions wise by 75. the 76s never met 76 emissions standards and certification. were sold as 76 model year but under the certification regime were classed as 75s if manufacture ceased by end of calendar year 1975 - which they did. Why are 76 914s subject to smog testing in CA? I mean, they should only have to meet the 1975 standards which is no smogging. ok mrholland and brant here is the link to the topic where the CARB specification/certification is posted for the 75 and 76 2.0. http://www.914world.com/bbs2/index.php?sho...64241&st=20 and here is the info on how model year cars were defined in terms of which calendar year standards were applied. don't get a headache reading. classic legal gobble de gook you have to read 5 times and think did i just understand that or....... (IMG:style_emoticons/default/confused24.gif) and this is the very strict limitation put on 76 914 CARB certification. the certificates for all the other MY 914s do not have this limitation. sh$t i stumbled across researching entirely unrelated matter of 1.8 L jets. because 74 L jets have weird vague emissions stickers that we recently discovered the USEPA and CARB must have pulled them up on so they had to correct the emissions stickers for the last month of 74 49 state 1.8s. its whacky stuff. classic regulation bureaucracy stuff. they are a slow chasing you but they never give up (has been my experience in life (IMG:style_emoticons/default/biggrin.gif) ) took em all year to catch up with VW on the 74 1.8 914 but they caught em right at the end and made them fix it. since stumbling on this i have worked out at least three cars that sneaked through on this techicality. the 1970 ford falcon. the 1974 VW 412 fastback with manual transmission (49 states) the 1976 914 2.0 (both california and 49 states). although they did not really sneak through. these were end of the line models. no more afterwards. so the USEPA ok'd it. its actually why the falcon model name disappears in the USA. its to satisfy the USEPA that its genuine termination and not a sneak around. the point about a 76 914 is that it isn't the CARB waving around some abstract emissions limits in the air, they are pulling out the certification documents. and those are identical to the 75 model because though it is a 76 it qualified for 75 level emissions. it is not build in a time period that includes Jan 01 of its model year. hilarious. it still obviously gets caught out for smogging exclusion cut off date because CARB are probably setting that trigger as a model year rather than a calendar year. its one of those things that you guys invented for yourselfs. the weird concept of a model year which is aug of the year before to july of year named. we didn't have this down here. model years conformed to calendar years. and i know why. our summer break was in january. natural time to shut down factory to gear up for new model changes. |
L-Jet914 |
Jun 6 2024, 01:06 AM
Member Group: Members Posts: 277 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
So if this was the case: i suspect that no matter what D jet hit the wall emissions wise by 75. the 76s never met 76 emissions standards and certification. were sold as 76 model year but under the certification regime were classed as 75s if manufacture ceased by end of calendar year 1975 - which they did. Why are 76 914s subject to smog testing in CA? I mean, they should only have to meet the 1975 standards which is no smogging. ok mrholland and brant here is the link to the topic where the CARB specification/certification is posted for the 75 and 76 2.0. http://www.914world.com/bbs2/index.php?sho...64241&st=20 and here is the info on how model year cars were defined in terms of which calendar year standards were applied. don't get a headache reading. classic legal gobble de gook you have to read 5 times and think did i just understand that or....... (IMG:style_emoticons/default/confused24.gif) and this is the very strict limitation put on 76 914 CARB certification. the certificates for all the other MY 914s do not have this limitation. sh$t i stumbled across researching entirely unrelated matter of 1.8 L jets. because 74 L jets have weird vague emissions stickers that we recently discovered the USEPA and CARB must have pulled them up on so they had to correct the emissions stickers for the last month of 74 49 state 1.8s. its whacky stuff. classic regulation bureaucracy stuff. they are a slow chasing you but they never give up (has been my experience in life (IMG:style_emoticons/default/biggrin.gif) ) took em all year to catch up with VW on the 74 1.8 914 but they caught em right at the end and made them fix it. since stumbling on this i have worked out at least three cars that sneaked through on this techicality. the 1970 ford falcon. the 1974 VW 412 fastback with manual transmission (49 states) the 1976 914 2.0 (both california and 49 states). although they did not really sneak through. these were end of the line models. no more afterwards. so the USEPA ok'd it. its actually why the falcon model name disappears in the USA. its to satisfy the USEPA that its genuine termination and not a sneak around. the point about a 76 914 is that it isn't the CARB waving around some abstract emissions limits in the air, they are pulling out the certification documents. and those are identical to the 75 model because though it is a 76 it qualified for 75 level emissions. it is not build in a time period that includes Jan 01 of its model year. hilarious. it still obviously gets caught out for smogging exclusion cut off date because CARB are probably setting that trigger as a model year rather than a calendar year. its one of those things that you guys invented for yourselfs. the weird concept of a model year which is aug of the year before to july of year named. we didn't have this down here. model years conformed to calendar years. and i know why. our summer break was in january. natural time to shut down factory to gear up for new model changes. Here in California as of current all 1976 and newer vehicles are subject to the smog check program. 1976-1999 get ASM (Acceleration Simulation Mode dyno) or TSI (Two Speed Idle) with the exhaust probe in the tail pipe. All 00 and newer MY vehicles get OIS testing (OBD II test, visual component inspection, visual smoke tests, no more tail pipe). The only reason why 1976 and newer vehicles are in the program is because of Arnold Schwarzenegger instead of allowing a rolling 25 year exemption like most states, put the smog exemption on vehicles produced before 1976 i.e. 1975 and older vehicles to answer @mrholland2 question. I know the last time I took an update course for my smog repair technician license that the CARB and BAR were in talks of exempting 1976-1995 vehicles at one point. I will ask about any new news when I go to my update course this weekend. I know if I stand on any street corner in my area I can count the number of pre-1996 vehicles going through the intersection on 1 or 2 hands. It's costing the state a significant amount of money to try and keep these 1976 to 1995 vehicle running clean, let alone trying to find emissions components for these vehicles that have since been discontinued many moons ago. Also to answer your inquiry about catalytic converters for Pre-OBD vehicles @wonkipop , the rules regarding aftermarket catalytic converters for these vehicle have changed to the point now as long as it meets the specific vehicle criteria PC-1 (passenger car with 1 cat), PC-2 (passenger car with 2 cats), T-1 (truck with 1 cat), T-2 (truck with 2 cats) the vehicle will pass smog without having to verify the CARB EO for the vehicle instead of verifying vehicle make, model, year, engine size. As long as the CARB EO number applies to the PC-1 etc it passes for that component. Now as for the other components that are now unobtainium that's a different story. |
wonkipop |
Jun 6 2024, 03:39 PM
So if this was the case: i suspect that no matter what D jet hit the wall emissions wise by 75. the 76s never met 76 emissions standards and certification. were sold as 76 model year but under the certification regime were classed as 75s if manufacture ceased by end of calendar year 1975 - which they did. Why are 76 914s subject to smog testing in CA? I mean, they should only have to meet the 1975 standards which is no smogging. ok mrholland and brant here is the link to the topic where the CARB specification/certification is posted for the 75 and 76 2.0. http://www.914world.com/bbs2/index.php?sho...64241&st=20 and here is the info on how model year cars were defined in terms of which calendar year standards were applied. don't get a headache reading. classic legal gobble de gook you have to read 5 times and think did i just understand that or....... (IMG:style_emoticons/default/confused24.gif) and this is the very strict limitation put on 76 914 CARB certification. the certificates for all the other MY 914s do not have this limitation. sh$t i stumbled across researching entirely unrelated matter of 1.8 L jets. because 74 L jets have weird vague emissions stickers that we recently discovered the USEPA and CARB must have pulled them up on so they had to correct the emissions stickers for the last month of 74 49 state 1.8s. its whacky stuff. classic regulation bureaucracy stuff. they are a slow chasing you but they never give up (has been my experience in life (IMG:style_emoticons/default/biggrin.gif) ) took em all year to catch up with VW on the 74 1.8 914 but they caught em right at the end and made them fix it. since stumbling on this i have worked out at least three cars that sneaked through on this techicality. the 1970 ford falcon. the 1974 VW 412 fastback with manual transmission (49 states) the 1976 914 2.0 (both california and 49 states). although they did not really sneak through. these were end of the line models. no more afterwards. so the USEPA ok'd it. its actually why the falcon model name disappears in the USA. its to satisfy the USEPA that its genuine termination and not a sneak around. the point about a 76 914 is that it isn't the CARB waving around some abstract emissions limits in the air, they are pulling out the certification documents. and those are identical to the 75 model because though it is a 76 it qualified for 75 level emissions. it is not build in a time period that includes Jan 01 of its model year. hilarious. it still obviously gets caught out for smogging exclusion cut off date because CARB are probably setting that trigger as a model year rather than a calendar year. its one of those things that you guys invented for yourselfs. the weird concept of a model year which is aug of the year before to july of year named. we didn't have this down here. model years conformed to calendar years. and i know why. our summer break was in january. natural time to shut down factory to gear up for new model changes. Here in California as of current all 1976 and newer vehicles are subject to the smog check program. 1976-1999 get ASM (Acceleration Simulation Mode dyno) or TSI (Two Speed Idle) with the exhaust probe in the tail pipe. All 00 and newer MY vehicles get OIS testing (OBD II test, visual component inspection, visual smoke tests, no more tail pipe). The only reason why 1976 and newer vehicles are in the program is because of Arnold Schwarzenegger instead of allowing a rolling 25 year exemption like most states, put the smog exemption on vehicles produced before 1976 i.e. 1975 and older vehicles to answer @mrholland2 question. I know the last time I took an update course for my smog repair technician license that the CARB and BAR were in talks of exempting 1976-1995 vehicles at one point. I will ask about any new news when I go to my update course this weekend. I know if I stand on any street corner in my area I can count the number of pre-1996 vehicles going through the intersection on 1 or 2 hands. It's costing the state a significant amount of money to try and keep these 1976 to 1995 vehicle running clean, let alone trying to find emissions components for these vehicles that have since been discontinued many moons ago. Also to answer your inquiry about catalytic converters for Pre-OBD vehicles @wonkipop , the rules regarding aftermarket catalytic converters for these vehicle have changed to the point now as long as it meets the specific vehicle criteria PC-1 (passenger car with 1 cat), PC-2 (passenger car with 2 cats), T-1 (truck with 1 cat), T-2 (truck with 2 cats) the vehicle will pass smog without having to verify the CARB EO for the vehicle instead of verifying vehicle make, model, year, engine size. As long as the CARB EO number applies to the PC-1 etc it passes for that component. Now as for the other components that are now unobtainium that's a different story. tight info. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) interesting use of words there @L-Jet914 . "[u]cars produced before 1976"[/u]. is that the wording the excemption legislation uses? if it is the 76 914 would fulfil the definition. its not produced in 1976. its production period is not inclusive of jan 01 1976. apart from stating what the emissions equipment is on it the CARB certification also makes it clear that it was certified on the basis it was not manufactured after dec 31 1975. the production period it is built in includes only Jan 01 1975 which defines its model year as calendar year 1975 under the statutes (federal law). i believe if anyone could be bothered they could push this with the powers that be at your registration board whatever it is called in california. you would have to be patient. it is entirely dependant on the precise wording of the excemption definition. |
L-Jet914 |
Jun 6 2024, 06:25 PM
So if this was the case: i suspect that no matter what D jet hit the wall emissions wise by 75. the 76s never met 76 emissions standards and certification. were sold as 76 model year but under the certification regime were classed as 75s if manufacture ceased by end of calendar year 1975 - which they did. Why are 76 914s subject to smog testing in CA? I mean, they should only have to meet the 1975 standards which is no smogging. ok mrholland and brant here is the link to the topic where the CARB specification/certification is posted for the 75 and 76 2.0. http://www.914world.com/bbs2/index.php?sho...64241&st=20 and here is the info on how model year cars were defined in terms of which calendar year standards were applied. don't get a headache reading. classic legal gobble de gook you have to read 5 times and think did i just understand that or....... (IMG:style_emoticons/default/confused24.gif) and this is the very strict limitation put on 76 914 CARB certification. the certificates for all the other MY 914s do not have this limitation. sh$t i stumbled across researching entirely unrelated matter of 1.8 L jets. because 74 L jets have weird vague emissions stickers that we recently discovered the USEPA and CARB must have pulled them up on so they had to correct the emissions stickers for the last month of 74 49 state 1.8s. its whacky stuff. classic regulation bureaucracy stuff. they are a slow chasing you but they never give up (has been my experience in life (IMG:style_emoticons/default/biggrin.gif) ) took em all year to catch up with VW on the 74 1.8 914 but they caught em right at the end and made them fix it. since stumbling on this i have worked out at least three cars that sneaked through on this techicality. the 1970 ford falcon. the 1974 VW 412 fastback with manual transmission (49 states) the 1976 914 2.0 (both california and 49 states). although they did not really sneak through. these were end of the line models. no more afterwards. so the USEPA ok'd it. its actually why the falcon model name disappears in the USA. its to satisfy the USEPA that its genuine termination and not a sneak around. the point about a 76 914 is that it isn't the CARB waving around some abstract emissions limits in the air, they are pulling out the certification documents. and those are identical to the 75 model because though it is a 76 it qualified for 75 level emissions. it is not build in a time period that includes Jan 01 of its model year. hilarious. it still obviously gets caught out for smogging exclusion cut off date because CARB are probably setting that trigger as a model year rather than a calendar year. its one of those things that you guys invented for yourselfs. the weird concept of a model year which is aug of the year before to july of year named. we didn't have this down here. model years conformed to calendar years. and i know why. our summer break was in january. natural time to shut down factory to gear up for new model changes. Here in California as of current all 1976 and newer vehicles are subject to the smog check program. 1976-1999 get ASM (Acceleration Simulation Mode dyno) or TSI (Two Speed Idle) with the exhaust probe in the tail pipe. All 00 and newer MY vehicles get OIS testing (OBD II test, visual component inspection, visual smoke tests, no more tail pipe). The only reason why 1976 and newer vehicles are in the program is because of Arnold Schwarzenegger instead of allowing a rolling 25 year exemption like most states, put the smog exemption on vehicles produced before 1976 i.e. 1975 and older vehicles to answer @mrholland2 question. I know the last time I took an update course for my smog repair technician license that the CARB and BAR were in talks of exempting 1976-1995 vehicles at one point. I will ask about any new news when I go to my update course this weekend. I know if I stand on any street corner in my area I can count the number of pre-1996 vehicles going through the intersection on 1 or 2 hands. It's costing the state a significant amount of money to try and keep these 1976 to 1995 vehicle running clean, let alone trying to find emissions components for these vehicles that have since been discontinued many moons ago. Also to answer your inquiry about catalytic converters for Pre-OBD vehicles @wonkipop , the rules regarding aftermarket catalytic converters for these vehicle have changed to the point now as long as it meets the specific vehicle criteria PC-1 (passenger car with 1 cat), PC-2 (passenger car with 2 cats), T-1 (truck with 1 cat), T-2 (truck with 2 cats) the vehicle will pass smog without having to verify the CARB EO for the vehicle instead of verifying vehicle make, model, year, engine size. As long as the CARB EO number applies to the PC-1 etc it passes for that component. Now as for the other components that are now unobtainium that's a different story. tight info. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) interesting use of words there @L-Jet914 . "[u]cars produced before 1976"[/u]. is that the wording the excemption legislation uses? if it is the 76 914 would fulfil the definition. its not produced in 1976. its production period is not inclusive of jan 01 1976. apart from stating what the emissions equipment is on it the CARB certification also makes it clear that it was certified on the basis it was not manufactured after dec 31 1975. the production period it is built in includes only Jan 01 1975 which defines its model year as calendar year 1975 under the statutes (federal law). i believe if anyone could be bothered they could push this with the powers that be at your registration board whatever it is called in california. you would have to be patient. it is entirely dependant on the precise wording of the excemption definition. @wonkipop I should have been more specific. MY1975 vehicles and older are exempt from the California smog check program currently. MY1976 to MY1999 are subject to tail pipe testing. MY2000 and newer get the OIS (OBD Inspection System) test. |
Lo-Fi Version | Time is now: 28th October 2024 - 04:20 AM |
