Wiring Harness Plastic Sheathing? |
TINKERGINEERING |
Jun 6 2024, 06:26 PM
Member Group: Members Posts: 207 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California |
Currently working on the wiring harness and found a couple wires in desperate need of replacement but they go through this plastic sheathing on the harness. Has anybody replaced wires through this sheathing? Should I just pull the wires out and try and jam them back in? I was also thinking I could just replace the sheathing, because it is 50 years old now, but how would I put new sheathing back on?
Thanks so much Attached thumbnail(s) |
Superhawk996 |
Jun 8 2024, 11:38 AM
914 Guru Group: Members Posts: 6,464 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Spend some time on YouTube learning how to de-pin connectors
https://youtu.be/Vt_rAIKPlWA?si=2n7Jm-KKKMoxBn8Q The ability to de-pin connectors is a game changer and will allow you to run wiring through Raychem sleeve without worrying about fitting the connectors through. After the wiring is pulled through, re-pin the connectors. 914 connectors are very easy to de-pin vs other more modern connectors. Use of spit convolute and the ability to put it on wiring harnesses without connectors having to be removed is its only redeeming characteristic. |
TINKERGINEERING |
Jun 8 2024, 03:15 PM
Spend some time on YouTube learning how to de-pin connectors https://youtu.be/Vt_rAIKPlWA?si=2n7Jm-KKKMoxBn8Q The ability to de-pin connectors is a game changer and will allow you to run wiring through Raychem sleeve without worrying about fitting the connectors through. After the wiring is pulled through, re-pin the connectors. 914 connectors are very easy to de-pin vs other more modern connectors. Use of spit convolute and the ability to put it on wiring harnesses without connectors having to be removed is its only redeeming characteristic. so the spade ends that go into them will fit through just fine? thats the only thing Im worried about |
SirAndy |
Jun 8 2024, 06:16 PM
Resident German Group: Admin Posts: 41,802 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so the spade ends that go into them will fit through just fine? thats the only thing Im worried about You may have to remove the spade connectors on the ends but you can re-crimp them easily with a good crimping tool. There's also no need to cut the connectors off at all, you can undo the factory crimp if needed. (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 16th September 2024 - 01:05 PM |
