Lower fuel line questions (under tank) |
DC_neun_vierzehn |
Jun 9 2024, 07:48 AM
Member Group: Members Posts: 437 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Looking for help regarding correct fuel lines while I await a new Dansk tank to replace the unusable one I received (thread here).
I have a '73 2.0. A PO moved the fuel pump up front and under the tank and cut out a door so that the fuel pump can be accessed from the frunk (like the '75 and '76). First question: regarding the send and return pipes on the bottom of the tank - the send line measures at 10 mm and the return at 8 mm, yet the list in the AA fuel line kit lists both lines as 7 mm. Is that correct? I didn't want to force it, but I cannot seem to get the 7 mm line in the kit over that 10 mm pipe. Here are pics of the pipes I'm speaking of as well as pics of what the lines were when I removed the old tank (a 5/16 AKA 7.9 mm USA made line on the send and a 7 x 3 made in Germany line on the return). |
bdstone914 |
Jun 9 2024, 09:45 AM
bdstone914 Group: Members Posts: 4,657 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Use rubber lines that fit your fittings.
7.5 and 9.5mm. They have to mate to the lines in the tunnel. |
Lo-Fi Version | Time is now: 16th September 2024 - 02:07 PM |
