> stuck in reverse, Transmission is stuck in reverse
PCH
post Jun 9 2024, 04:55 AM
Hi Everyone!
I took my ‘71 1.7 to the car wash yesterday. When I picked it up, they told me it was stuck in reverse.
Sure enough, the gearbox is stuck in reverse. It seems like you can shift back and forth between 4 and 5, but in those positions the gearbox is just locked up; feeling like “park” in an automatic transmission. Shifting back and forth in neutral only left the gearbox in reverse.
On my initial search of the internet, I came across mentions of a car being shift ed between first and reverse while still moving and this could cause this. Also there was a mention of doing something with the reverse light pin to get it out of reverse.
Is there an emergency fix for this problem and what is the long term repair?
Thanks everyone,
Peter
rhodyguy
post Jun 9 2024, 02:47 PM
Did the shifting seem vague at all prior to the problem? On the bottom of the rear of the trans there is an access plate below where the linkage enters the trans. A triple rolled pin that lives above the plate on the linkage. When that pin gives up the ghost you can’t adjust away the shifting issue. As mentioned, check all of the bushings related to the shift linkage.
- Lo-Fi Version Time is now: 14th March 2025 - 01:16 PM
