> Terrible front wobble. Bearing/ spindle spacer question.
roundtwo
post Jun 12 2024, 10:48 PM
Front bearing / spacer help - so close to on the road
914 six almost ready to go after getting it tuned on a dyno today. More about that later.
- trying to chase down the source of the shaking front end.
- Vetted out wheels, tires, tie rods, shocks, bushings, rotor warpage, etc…. All good
-Please see pics.
It seems as if there’s a mismatch between the inner bearing and the spacer. Somethings not right but I don’t know what it is.
The last true leftover problem from the previous owner.
24 mm carrera rotors, Porsche Brenbo brakes, 911 hubs,
new bearings and seals.
Any clue at to what’s wrong?
post Jun 13 2024, 04:11 AM
914-6 GT in waiting
The hub and bearings either fit on the strut or they don’t. If they fit and spin smoothly, they aren’t going to wobble.
I would try a different set of wheels and tires on the car. It’s usually the tires that are the problem.
roundtwo   Terrible front wobble. Bearing/ spindle spacer question.   Jun 12 2024, 10:48 PM
roundtwo   RE: Terrible front wobble. Bearing/ spindle spacer question.   Jun 12 2024, 10:50 PM
mepstein   The hub and bearings either fit on the strut or th...   Jun 13 2024, 04:11 AM
mate914   Tires can do what you are feeling. I once changed ...   Jun 13 2024, 05:02 AM
mb911   I believe Todd replaced tires already. I have had ...   Jun 13 2024, 05:40 AM
rfinegan   What wheels? Hub verse lug centrical wheels gives ...   Jun 13 2024, 05:52 AM
Superhawk996   Everything you measured has nothing to do with the...   Jun 13 2024, 11:04 AM
mepstein   We had a customer with a similar issue. He swore i...   Jun 13 2024, 11:13 AM
technicalninja   My first Z pulled violently to the left. Had a ben...   Jun 13 2024, 11:20 AM
ChrisFoley   With the car up in the air, grab a wheel at top an...   Jun 13 2024, 11:28 AM
Superhawk996   With the car up in the air, grab a wheel at top a...   Jun 13 2024, 11:45 AM
technicalninja   Right after you do what Chris suggests spin the wh...   Jun 13 2024, 11:45 AM
Superhawk996   Right after you do what Chris suggests spin the w...   Jun 13 2024, 12:09 PM
technicalninja   :agree: :agree: :agree: However, if you can se...   Jun 13 2024, 12:39 PM
infraredcalvin   Agree on tires, i put Toyo r888rs on both my cars,...   Jun 13 2024, 01:43 PM
Krieger   Did you check to see if the steering rack is tight...   Jun 13 2024, 11:10 PM
roundtwo   @chrisfoley [b]@[url=http://www.914world.com/bbs...   Jun 13 2024, 11:12 PM
roundtwo   RE: Terrible front wobble. Bearing/ spindle spacer question.   Jun 13 2024, 11:15 PM
roundtwo   See previous pic 1. When I slide on the rotor hu...   Jun 13 2024, 11:21 PM
ChrisFoley   The inner bearing inner race is supposed to contac...   Jun 14 2024, 08:55 AM
technicalninja   OK, you put 500 miles on it before the "wheel...   Jun 14 2024, 10:59 AM
roundtwo   @chrisfoley Thanks so much Chris… so it looks...   Jun 14 2024, 12:52 PM
mepstein   I hope you try a different set of wheels and tires...   Jun 14 2024, 01:19 PM
- Lo-Fi Version Time is now: 15th January 2025 - 08:59 AM
