Terrible front wobble. Bearing/ spindle spacer question. |
roundtwo |
Jun 12 2024, 10:48 PM
Member Group: Members Posts: 311 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Front bearing / spacer help - so close to on the road
914 six almost ready to go after getting it tuned on a dyno today. More about that later. - trying to chase down the source of the shaking front end. - Vetted out wheels, tires, tie rods, shocks, bushings, rotor warpage, etc…. All good -Please see pics. It seems as if there’s a mismatch between the inner bearing and the spacer. Somethings not right but I don’t know what it is. The last true leftover problem from the previous owner. 24 mm carrera rotors, Porsche Brenbo brakes, 911 hubs, new bearings and seals. Any clue at to what’s wrong? |
ChrisFoley |
Jun 13 2024, 11:28 AM
I am Tangerine Racing Group: Members Posts: 7,975 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With the car up in the air, grab a wheel at top and bottom and try to rock it up and down.
Anything wrong with the wheel bearing fitment will show up right away. The wheel should move only a small amount when the bearing preload is correct. |
Superhawk996 |
Jun 13 2024, 11:45 AM
914 Guru Group: Members Posts: 6,663 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
With the car up in the air, grab a wheel at top and bottom and try to rock it up and down. Anything wrong with the wheel bearing fitment will show up right away. The wheel should move only a small amount when the bearing preload is correct. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 09:07 AM |
