Terrible front wobble. Bearing/ spindle spacer question. |
roundtwo |
Jun 12 2024, 10:48 PM
Member Group: Members Posts: 311 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Front bearing / spacer help - so close to on the road
914 six almost ready to go after getting it tuned on a dyno today. More about that later. - trying to chase down the source of the shaking front end. - Vetted out wheels, tires, tie rods, shocks, bushings, rotor warpage, etc…. All good -Please see pics. It seems as if there’s a mismatch between the inner bearing and the spacer. Somethings not right but I don’t know what it is. The last true leftover problem from the previous owner. 24 mm carrera rotors, Porsche Brenbo brakes, 911 hubs, new bearings and seals. Any clue at to what’s wrong? |
technicalninja |
Jun 13 2024, 11:45 AM
Advanced Member Group: Members Posts: 2,259 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Right after you do what Chris suggests spin the wheel and align the tire tread surface with a straight edge you place on the floor.
The human eye can see .001" of run out. If you have a bulge, internal tire issue, you can often see it this way. Has to pass Chris Foley's test FIRST! I set my adjustable wheel bearing clearance so there is almost no play at all. If you're using new bearings and races recheck this clearance after the first 100 miles. Most need a tiny bit of "tighten" at this point. |
Superhawk996 |
Jun 13 2024, 12:09 PM
914 Guru Group: Members Posts: 6,663 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Right after you do what Chris suggests spin the wheel and align the tire tread surface with a straight edge you place on the floor. The human eye can see .001" of run out. If you have a bulge, internal tire issue, you can often see it this way. Has to pass Chris Foley's test FIRST! I set my adjustable wheel bearing clearance so there is almost no play at all. If you're using new bearings and races recheck this clearance after the first 100 miles. Most need a tiny bit of "tighten" at this point. Though I agree with all above, it should be noted that you can’t see imbalance and you can’t see radial 1st harmonic tire (R1H) effects but they surely can be felt on the road as the symptoms you describe. At this point, it no longer surprises me when tire shops screw up simple balance. Finding tire shops with road force machines with technicians that actually know how to use them properly to counter act a tire with a high R1H problem is a task unto itself and you will pay “extra” for road force balancing. |
Lo-Fi Version | Time is now: 15th January 2025 - 09:01 AM |
