torakki |
Member ![]() ![]() Group: Members Posts: 55 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California ![]() |
I've read where it's a good idea to remove the head gaskets and re-assemble without them. Something about, they crush and cause an issue. Is there anything else you need to do or change, in their place? Like a different head design?
Thanks |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,050 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I built my 2056 a couple years ago (still running great) and used small pieces of Plastigage at quarter points of the top of the cylinders and torqued the head(s) down. The results showed near equal dimensions at all locations. I do recall reading the factory recommended to eliminate the head gaskets and the engineering regarding the cast iron barrels and the aluminum cylinder heads. I did not use head gaskets, but a paper gasket at the case/cylinder connection.
Lo-Fi Version | Time is now: 26th April 2025 - 02:43 AM |
