torakki |
Member ![]() ![]() Group: Members Posts: 55 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California ![]() |
I've read where it's a good idea to remove the head gaskets and re-assemble without them. Something about, they crush and cause an issue. Is there anything else you need to do or change, in their place? Like a different head design?
Thanks |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,928 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Since Clay responded I need to clarify my post. Stock cylinders - pistons and heads. If you check the cylinders to verify the registers are not collapsed and the heads are only in need of new guides you can the heads to make sure you have a clean mate up and gain a slight compression increase by leaving out the head gasket. It may or may not be the recommended method. But I have done it successfully.
Lo-Fi Version | Time is now: 26th April 2025 - 02:40 AM |
