901 ring and pinion setup |
Driver174 |
Jun 16 2024, 05:30 PM
Member Group: Members Posts: 107 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
How does one learn the correct way to install a ring and pinion gear set into a 901 gearbox? What tools/fixtures are required to do this, and where can they be found?
I have successfully been into transmissions several times for my race car, and this was made possible by resources from Dr. Evil; Thanks a bunch Mike! Now I would like to be able to install another gear set or LSD module. |
mgphoto |
Jun 17 2024, 10:45 AM
"If there is a mistake it will find me" Group: Members Posts: 1,364 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
How does one learn the correct way to install a ring and pinion gear set into a 901 gearbox? What tools/fixtures are required to do this, and where can they be found? I have successfully been into transmissions several times for my race car, and this was made possible by resources from Dr. Evil; Thanks a bunch Mike! Now I would like to be able to install another gear set or LSD module. The best place to look is the factory repair manual, it has the procedure and the list of tools needed, but there are errors, mostly omissions. Tool that is most important is the VW 385 and complimenting attachments. I installed a factory ZF LSD and it went smoothly. |
Lo-Fi Version | Time is now: 28th October 2024 - 05:20 AM |
