Villemi |
Newbie ![]() Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France ![]() |
Hello,
We know on our D -Jetronic harness some male connectors 2,3,4,5 ways with female connectors with female pins inside. (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640445696.1.jpg) Do you know female connectors with male pins inside. ? I need your help because I want to use on my 914 Porsche a 123 ignition distributor. For the OEM distributor I have a 3 ways female connector and for the harness 3ways male connector I'd like to make a little harness with a 3 ways male on one side and 3 ways female connector on the other side It's easy to find male connectors with female pins but I don't find female connector with male pins. Do you know where I can find these parts ? The advantage of this little harness is if I have problems with the 123 ignition distributor I can use my OEM one without harness modification. Can you help me please ? PS: what is the item number of these D-Jetronic connectors ? Best regards Michel |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,320 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Why not convert it to a crimp-on Deutsch-type connector? When I built the wiring harness for my Microsquirt conversion (see sig), I used these on everything:
https://www.amazon.com/gp/product/B07L9XNFGG Those are available in much larger quantities (for example, there's a 152-piece set). I much prefer the true Deutsch barrel connectors but these are much more affordable, and they require standard hand wiring tools, |
Lo-Fi Version | Time is now: 2nd July 2024 - 01:41 AM |
