> Anyone tried an aircooled Flat 8, With two fours?
r_towle
post Jan 28 2005, 12:49 PM
Custom Member
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions.
Assumptions
2 motors each producing 100 HP and 100 Lb/ft of Torque
The motors are end to end, front to rear.
The cranks are fastened together either bolted or welded.
1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque..
2) could it be done with a single ignition system available for sale off the shelf.
3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from.
4) I am assuming either a nice FI system, or four carbs.
Has anyone done this?
I would like to see some articles or web pages if this has been done in the aircooled world...
Thanx in advance
Rich
r_towle
post Jan 30 2005, 06:37 PM
Custom Member
QUOTE (DuckRyder @ Jan 30 2005, 04:18 PM)
Thinking out loud:
Couldn't you slice one case disecting it between the bores (that would require an angle or zig zag)  :sawzall:
then slice the ends off of the other case to insert it in between the front and back of the other two halves.  :welder:
That make sense?  :blink:
(IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)  :burnout:
ok, ill bite, why would i do that versus cutting the back off one and the front off the other.......
BTW It looks like the oil galleys can line up if it is cut in the correct place.
I would go with a dry sump.
Rich
r_towle   Anyone tried an aircooled Flat 8   Jan 28 2005, 12:49 PM
Mueller   yep, a few have been done........I know I've p...   Jan 28 2005, 01:03 PM
sanman   I thought of it but I think it would be too lo...   Jan 28 2005, 01:05 PM
r_towle   i was hoping you would answer...you always think o...   Jan 28 2005, 01:05 PM
andys   It's been done both ways. I saw a pic years ag...   Jan 28 2005, 01:08 PM
r_towle   honestly cooling seems like a simple part of it .....   Jan 28 2005, 01:14 PM
Cloudbuster   Double displacement does not usually equal double ...   Jan 28 2005, 01:22 PM
nebreitling   i would think that you could never get double the ...   Jan 28 2005, 01:36 PM
Jake Raby   Already have a print in with moldex on the crank. ...   Jan 28 2005, 01:59 PM
synthesisdv   asked the same question a while back.... here...   Jan 28 2005, 02:19 PM
Cloudbuster   Hans Dahlbeck? Isn't he the brain donor in ...   Jan 28 2005, 02:23 PM
synthesisdv     Jan 28 2005, 05:29 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 28 2005, 06:06 PM
Jake Raby   It won't cost a whole lot for me to do it, oth...   Jan 28 2005, 06:10 PM
Mueller   ...   Jan 28 2005, 06:13 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 28 2005, 06:28 PM
Bleyseng   screw two motors! put four of them together...   Jan 28 2005, 06:48 PM
redshift   <...   Jan 28 2005, 06:59 PM
Bleyseng   I am hoping to squeeze by with $5000, buying ...   Jan 28 2005, 07:01 PM
Jake Raby   Here it cost 6K for a stock rebuild, but you can a...   Jan 28 2005, 08:16 PM
r_towle   how would you do oiling on the rear engine??? See...   Jan 28 2005, 11:23 PM
Brando   or connect them at the cranks... if you're go...   Jan 29 2005, 05:12 AM
SpecialK   Screw pistons...........someone stick a Huey Turbi...   Jan 29 2005, 05:18 AM
BigD9146gt   http://www.914world.com/bbs2/html/e...   Jan 30 2005, 05:19 PM
r_towle   ok, When if any was the earliest time that an ove...   Jan 30 2005, 06:09 PM
DuckRyder   Thinking out loud: Couldn't you slice one cas...   Jan 30 2005, 06:18 PM
r_towle   <...   Jan 30 2005, 07:21 PM
URY914   Here's what you need...   Jan 30 2005, 08:09 PM
redshift     Jan 30 2005, 08:14 PM
URY914   <...   Jan 30 2005, 08:18 PM
Air_Cooled_Nut
  Jan 31 2005, 11:23 AM
jwalters   Wonder how the T4 would respond with a crank that...   Jan 31 2005, 02:47 PM
bondo   ...   Jan 31 2005, 02:50 PM
r_towle   yes, but what if you welded up the two motors to b...   Jan 31 2005, 05:28 PM
DuckRyder   ...   Jan 31 2005, 05:45 PM
jwalters   Very nice pic of a Duc!!! I am spankin...   Jan 31 2005, 05:52 PM
DuckRyder   ...   Jan 31 2005, 05:56 PM
JmuRiz   I know were're getting off topic here, but mmm...   Jan 31 2005, 11:06 PM
BigD9146gt   Nathan, I second that! MotoGP sould be great t...   Feb 1 2005, 12:34 PM
Al Meredith   I was out at Chuck Beck house (he lives outside At...   Feb 27 2006, 06:34 PM
Mueller   ...   Feb 27 2006, 07:15 PM
ClayPerrine   How about something like this??? http://www.perr...   Feb 27 2006, 07:51 PM
Mueller   ht...   Feb 27 2006, 08:01 PM
bd1308   i'll see if i can dig up two bus motors.... T...   Feb 27 2006, 08:02 PM
Brian Mifsud   Mike...while your in there pouring aluminum, how a...   Feb 27 2006, 08:22 PM
Brando   ...   Feb 27 2006, 08:54 PM
Brett W   The 180 degree 8 has a problem with second order i...   Feb 27 2006, 08:56 PM
Thorshammer   One of the problems must be the design of a crank ...   Feb 27 2006, 08:58 PM
alpha434   Why we couldn't use a Chevy crank: Counter ba...   Feb 27 2006, 09:03 PM
ClayPerrine   <...   Feb 27 2006, 09:06 PM
alpha434   ...   Feb 27 2006, 09:07 PM
lapuwali   ...   Feb 27 2006, 09:22 PM
Brett W   Sorry I was referring to a 180 degree V8. Don...   Feb 27 2006, 09:23 PM
JmuRiz
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 06:17 AM
