NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,086 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
I am moving my fuel pump from an up front location to a better up front location. The PO ran the power wire through a hole in the passenger foot well. I don't like that idea. Is there a better option that routes from the fuse box to in or around the steering rack area?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,597 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
When moving the fuel pump up front, I follow the wiring harness that is already in the car. You don't have to run two wires all the way from the back. Just one Black/yellow wire to extend the factory wire, and run it up to the front until it goes under the tank. Add a second ground wire from the ground point by the fuse block to where your pump is mounted.
In my opinion, anything else looks sloppy. |
Lo-Fi Version | Time is now: 2nd July 2024 - 02:38 AM |
