Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,606 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
For Sale:
Freshly replated parts. Prices include shipping to the lower 48 states: Rear mounted fuel pump brackets (3 available): $25 ea. The one on the right had the nut epoxied in place for some reason (IMG:style_emoticons/default/confused24.gif) $20 ![]() The one on the right (epoxied) ![]() Engine lid latch: $40 ![]() ![]() Parking brake short cable and parts: $20 (note condition (IMG:style_emoticons/default/dry.gif)) ![]() ![]() ![]() |
Montreal914 |
Bruce ( @bdstone914 ) , I am not so sure about that...
These were removed from fuel pump assembly. You can see the semi-circular notch on the top of the omega which is there to clear the fuel pump connector. The coil bracket doesn't have the circular notch. Edit: This is what I am referring to. I may be wrong, but I don't see any pictures of coil brackets with that notch. That being said, this bracket could probably be used for either (pump or coil). Get two for $40 shipped! (IMG:style_emoticons/default/biggrin.gif) ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,562 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Bruce ( @bdstone914 ) , I am not so sure about that... These were removed from fuel pump assembly. You can see the semi-circular notch on the top of the omega which is there to clear the fuel pump connector. The coil bracket doesn't have the circular notch. Edit: This is what I am referring to. I may be wrong, but I don't see any pictures of coil brackets with that notch. That being said, this bracket could probably be used for either (pump or coil). Get two for $40 shipped! (IMG:style_emoticons/default/biggrin.gif) ![]() You could be right. I have a couple coils with the brackets still on them. I wll see if they have that notch which i can't see that it serves a purpose. But if i am right that notch would provide clearance for the round connector housing. |
Lo-Fi Version | Time is now: 2nd July 2024 - 01:42 AM |
