NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,086 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
I am moving my fuel pump and drained the tank for the hose hook up etc. I looked deep inside and noticed a little residue on the bottom. I am going to pull the screen too, might be more there.
Is there something to use to flush the tank that is not fuel? This will be with the tank in place. I am NOT taking it out. Scope creep is killing me and I am already missing the best part of the driving season. |
Jack Standz |
Member ![]() ![]() Group: Members Posts: 298 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() |
Removing the tank is one fastener on the strap & disconnecting the fuel lines (that are being or should be replaced if they have any age at all on them). IIRC replacing the in-tank screen/"sock" isn't easy with the tank still in, but I'm not sure.
If it's loose dirt or crud that you're trying to clean out, how could you get it out with the reserve tank/reservoir at the bottom of the tank? (Mabe using the above "mop" method) Take it outside and spray some carb celaner in there, maybe let it soak awhile, then rinse out with some fuel. |
Lo-Fi Version | Time is now: 2nd July 2024 - 01:18 AM |
