Targa top pad removal - Phillips Head? |
DC_neun_vierzehn |
Jun 23 2024, 04:02 PM
Member Group: Members Posts: 443 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
bdstone914 |
Jun 23 2024, 10:47 PM
bdstone914 Group: Members Posts: 4,686 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@DC_neun_vierzehn
I removed a pad today and all of the screws were hidden behind deteriorating foam. I used a 1/4" drill bit turned slowly by hand to remove the loose foam until i could remove each screw. Use some canned air to clean them out. Look in with a flash light to find the screw head. |
DC_neun_vierzehn |
Jun 24 2024, 04:09 PM
@DC_neun_vierzehn I removed a pad today and all of the screws were hidden behind deteriorating foam. I used a 1/4" drill bit turned slowly by hand to remove the loose foam until i could remove each screw. Use some canned air to clean them out. Look in with a flash light to find the screw head. Good tip. Thanks. |
Lo-Fi Version | Time is now: 18th October 2024 - 12:17 AM |
