MPS Mapping, How and what info do you want? |
FlacaProductions |
May 30 2024, 01:06 PM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Many of you may remember my 123 Distributor install that finally worked out.
(here: http://www.914world.com/bbs2/index.php?sho...370332&hl=) I now have a vacuum pump and multi meter - TELL ME WHAT YOU WANT TO SEE. Unit is an 041 and has obviously been cracked open - before my time. It's marked with a Sharpie "74-76 2.0" which I believe is incorrect and should be for a 71-72 1.7. Maybe this accounts for the opening and potential adjustment. Currently holds 15in pretty much indefinitely and I get 93ohms between pins 7 and 15, and 344ohms between pins 8 and 10. All that seems pretty much right on - but it would NOT start after putting in the 123. Prior to the 123, it ran "fine" but then started running warm due to a distributor vacuum issue (more in another thread) Distributor was an 011 with a Pertronix Igniter II. Installed a "correct" 043 MPS and it fired right up and works great with the 123. Honestly - I'm just looking to acquire some database info for the World and then move this on, so if someone wants it, just yell. I have no idea what it's worth. |
emerygt350 |
Jun 24 2024, 12:10 PM
Advanced Member Group: Members Posts: 2,403 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
What was the number on the housing? The spacer is also interesting. This was on a 1.7?
rjames |
Jun 24 2024, 12:25 PM
I'm made of metal Group: Members Posts: 4,110 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
What was the number on the housing? The spacer is also interesting. This was on a 1.7? Bosch 0 280 100 041 VW 022 906 051 E Anders' web site doesn't show an entry for x041, but does show 022 906 051 E, which on Anders' site is associated with Bosch 0 280 100 049 (designed for a '70-'73 1.7 liter). Spacer was likely added to accommodate a 2 liter, which is what it was installed on. |
Superhawk996 |
Jun 24 2024, 04:49 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
What was the number on the housing? The spacer is also interesting. This was on a 1.7? Bosch 0 280 100 041 VW 022 906 051 E Anders' web site doesn't show an entry for x041, but does show 022 906 051 E, which on Anders' site is associated with Bosch 0 280 100 049 (designed for a '70-'73 1.7 liter). Spacer was likely added to accommodate a 2 liter, which is what it was installed on. For what it’s worth I also have an 041 that had a more typical copper beryllium pleated diaphragm. It too had a 2.0L spacer. I don’t have history on the part. It came to me with a cracked diaphragm. I assumed it had been “adapted” previously since body is the early screw type and it’s easy to open without showing signs like those that have rivets. Now I’m really wondering (IMG:style_emoticons/default/confused24.gif) Sorry I missed earlier post with curve (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 18th September 2024 - 07:09 PM |
